TIME SLIP DATABASE
Turbo NNBS only running 12.7, help me out.
Old Feb 5, 2016 | 11:01 PM
TAPyvehc93's Avatar
Default Turbo NNBS only running 12.7, help me out.
Looking for some advice from the more knowledgable/senior members here.
Here are the stats on the truck.
- 2011 GMC Sierra ECRB, 2wd.
- 5.3, 224/228@114 comp cam, Brian Tooley dual springs, TSP pushrods, LS7 lifters, Melling oil pump.
- Holley Hi-Ram intake and rails with 95LB Bosch injectors, return fuel system with a single Walbro 450 and a Holley fuel pressure regulator.
- Turbo kit is a stage III Trick kit with a 75/75 Turbonetics set to 9LBS via waste gate spring.
- Stock 6l80e with 2800 single disk Yank, 2 piece steel driveshaft, stock 3.42 gears with Eaton true-trac.
- Suspension mods are drop shackles, rear blocks removed and VAS traction bars.
- Running 15x10 Cragars with 28" Mt's
- Spare tire and hitch removed along with the back fold up seats removed as well.
Truck made 545 rwhp on 9LBS and e85. I feel like the truck should be a lot faster for what it is. Obviously my combination is off but I honestly don't know where to start. I was thinking maybe a bigger converter?? Anyways, attached below is a picture of my dyno graph and my time slip. Let me know what you think, thanks!!
Attached Thumbnails Turbo NNBS only running 12.7, help me out.-img_2849.jpg   Turbo NNBS only running 12.7, help me out.-img_2850.jpg
Old Feb 6, 2016 | 01:25 AM
George C....'s Avatar
Formerly ScreamingL
Intake is totally wrong for combo
And my truck is 4wd and crewcab with 540rwhp went 12.5@113 stock truck intake ftw
Much smaller cam and no stall
Get a smaller cam
Stock intake
And have at it
Old Feb 6, 2016 | 12:03 PM
ZO6Ted's Avatar
Good God with a 60' like that it could run a high 11 improving that alone! Did you leave on boost at all? My stocker cut a 1.99.
Old Feb 6, 2016 | 12:47 PM
vettelovralexand's Avatar
1/8th mile trap is strong for your 1/4 mile trap. Does the truck have to shift to 4th in the 1/4? Either way, there is definitely a lot of time to pick up in your 60'.
Old Feb 6, 2016 | 02:12 PM
TAPyvehc93's Avatar
I brake boosted the converter but it pushes through the brakes befor it can build any boost.
Old Feb 6, 2016 | 02:22 PM
fastjweb's Avatar
I ran a 7.69 at 89, 12.09 at 110 with a 1.69 60ft, to give you an idea. You need to leave under boost though or its not going to get much better, unless you have a looser converter, but you will loose out on top end. Ive added 4l80e swap, ptc 3500 converter, and went from 10-15lbs. I build 8-10 lbs with a 2 step and cut 1.54-156s and my time dropped to 11.02 at 121.2. I also run stock intake, tb, etc, and have a 70mm turbo.
Old Feb 6, 2016 | 02:24 PM
fastjweb's Avatar
those 3.42s are probably hurting you too, especially not leaving under boost.
Old Feb 6, 2016 | 04:37 PM
TAPyvehc93's Avatar
I don't think it does but I honestly don't know.
Old Feb 6, 2016 | 04:46 PM
TAPyvehc93's Avatar
So you think a 3400-3600 converter would help me build boost off the line? I was also going to do the hydro boost conversion. Also I thought turbos like the load from the 3:42 gears, especially with the 6l80e's short first gear.
Old Feb 6, 2016 | 04:52 PM
06 4.8's Avatar
Your pats cousin right? If I remember isn't your cam on a 112 lsa? Def a little tight for a turbo setup.
