TIME SLIP DATABASE
Tru Trac, 10 bolt diff advice
Old Aug 9, 2013 | 08:07 PM
  #31
Gadgetized's Avatar
Also can you measure to see how deep the grooves are in your C clips?
Old Aug 9, 2013 | 08:37 PM
  #32
pittman's Avatar
Originally Posted by Gadgetized
Both sides of my unit had 3 oil grooves. I doubt they changed the design. Check to see if they are full of debris.
Holy crap, you have to be kidding. I could not see any evidence of 3 groves. Damn I hate to take it apart again.
I will measure the groves
Old Aug 10, 2013 | 11:59 AM
  #33
pittman's Avatar
Measured the new and old C-clips at 3.83mm, or 0.151" or 5/32"
The old worn C-clips measured:
3.74mm or 9/64"
3.65mm or 9/64"
10/64" new with 2/64" difference added together or 1/32" total wear.
.151" new
.143" wear
.151" new
.146" wear
Sure doesn't seem like enough play to rub the gear into the case ??
Old Aug 11, 2013 | 12:15 PM
  #34
Gadgetized's Avatar
Here were my bad side and worse side. I think the most important thing is the new clips. If the clips are holding the gear away, it really shouldnt be scraping the housing.
Here was the not so bad side after i cleaned it up.
Old Aug 11, 2013 | 01:10 PM
  #35
pittman's Avatar
Looks great when cleaned up.
I am trying to decide if I should open mine back up and cut 2 more oil valley's on the side that only has 1 ? It didn't seem to wear any worse than yours.
Old Aug 11, 2013 | 01:34 PM
  #36
Gadgetized's Avatar
Well I put mine together with intentions of only running it until I got the 14 bolt in. Well here I am 2k miles later. And they arent easy miles. Every time I have it out I do an 80 MPH burnout.
Old Aug 12, 2013 | 05:28 PM
  #37
TIM Z's Avatar
11 sec. Truck Mod
Haha that's the way to drive it !
I just had the rear cover off and everything looked good but I didn't tare it apart to inspect . I'll rock it till if/when she breaks and then upgrade .
Old Aug 13, 2013 | 08:47 AM
  #38
pittman's Avatar
Yeah it has to be taken apart to see the wear. Just run it till it drops out...haha.
Mine going back together this weekend. I just got the shims last night. I bought some nice steel ones in a kit. No more GM cast shims for me.
Old Aug 13, 2013 | 09:17 AM
  #39
walledition's Avatar
i was thinking just before i sow this thread what happend with your truck i hadnt seen anything in a while, glad your still working on it, you should post pictures and videos of it, love that truck, good luck
Old Aug 13, 2013 | 10:10 AM
  #40
pittman's Avatar
Thanks man.
I haven't run since Nov 2011, beside trying to work out shifting issues with the tune. I went to MIR (Maryland) for some good air and ran 5 new best times of 11.16, 11.16, 11.15, 11.15 & 11.14. Since then, Over the last few months I have added 16" Bogarts, new rubber, had the tranny rebuilt, added new TSP Headers, Vette coil pacs/wires, rewired most under hood connections, added a 102mmMaf, retuned and now the diff went out. Also had to repaint the roof from a tree branch falling on it.
I now have the tranny running a 9" - SS3600 Yank Stall instead of the 10.5" Pro Series 3600 previously. That should free up a little power. I still need to get my 2-3 shift adjusted (short shifting around 5200 rpm). Will get back to the track when it cools down some.
ADDED 16" BOGARTS & RUBBER
REWIRED MOST UNDERHOOD CONNECTIONS:
CHANGED TAIL LIGHTS
STREET TRIM, 4140 lbs:
