Traction problems at the track
!st time at the track since the new heads, cam, and converter. My times were worse than last year.
My tires were spinning BIG time. I can't do a burnout in the box because of being AWD. So what can I do to prevent or lessen the spin. I'm running my stock 20's.
What do you think? Any advice would be appreciated.
Thanks,
Mike
Thanks,
Mike
What he said. Also, you can drive through the water and pull forward a few. Then you can power out of it to clean the tires even if you don't get to do a full burnout. Don't forget to drop the tire pressure at the track. I think maybe I was running 22-24 back and maybe 26-28 front with my factory 20's when I ran my best time.
Thanks for the replies guys. Keep them coming.
My 60' is just over 2 seconds.
I lowered tire pressure to 23lbs all around and gave it a good stomp to clean the tires after the water box. The tires wouldn't break free.
I don't think I have enough room to drive around the water box. Would the VHT wash off once I went through the water?
The front is lowered but maybe some limiters and drag radials in the future. Where is a good place for drag radials?
Where is a good place to find some drag radials?
http://www.mandhtire.com/
