TIME SLIP DATABASE
track problems
Old Nov 19, 2009 | 04:02 PM
  #21
1dirtybird's Avatar
Same heads, cam, valve spring, t/b, displacement, pully size, exhaust, intake, intercooler, stall, tranny, gearing and tire? change any one of those and then some and it can change your boost. But comparing the 28 inch slicks to 25 inch street tires is apples to oranges. Jus some food for thought
Dirty
Old Nov 19, 2009 | 04:23 PM
  #22
Most Hated's Avatar
so if u were me what would u do this setup
6.0 LQ4 - LT'S,PATRIOT STG 2 HEADS , 231/247 617/623 115LSA PATRICK G SPECED CAM , PRO CHARGER D1, 3.6 PULLEY,TRU TRAC WITH 3.73'S ,3600 PI TRIPLE DISK STALL , BUILT 4L60E,
Old Nov 19, 2009 | 04:30 PM
  #23
AKlowriderZ71's Avatar
11 Second Hall Moniter
What rpm are you crossing the traps at?
Old Nov 19, 2009 | 04:49 PM
  #24
Most Hated's Avatar
to tell u the truth i dont rember cuz i was too cought up into to the a/f and boost gauges but more or less 50some i think cuz i lock up around 100 s the rpm goes back a lil u get me
Old Nov 19, 2009 | 07:32 PM
  #25
litreddevil's Avatar
Banned
you need to make up your mind you want it fast on the street are fast on the street and at the track.
i would change the cam.
Old Nov 19, 2009 | 07:43 PM
  #26
Most Hated's Avatar
well a lil bit of both lol yea im thinkin bout cam swaps
Old Nov 19, 2009 | 07:53 PM
  #27
1dirtybird's Avatar
Yep I'd run that, maybe a tad smaller cam.... But that set-up looks good for 525~575 rwhp in a truck. I think changing your tire size has a lot more effect on the way the motor revs. try running down the street on the slicks and compare that with the street tires. You may need to change pully size to get the boost you are looking for.
Old Nov 19, 2009 | 08:15 PM
  #28
I think you need a shorter tire at the track. You want to be crossing the finish line just over 6000 rpm.
pewter00
11
Oct 20, 2023 05:40 AM
GMCtrk
Jan 27, 2016 06:47 PM
zblee
Nov 11, 2015 12:41 AM
Justin87gn
Sep 10, 2015 12:06 PM
Boyes50
Sep 8, 2015 12:06 PM
