TIME SLIP DATABASE
Slow h/c 2500hd
Old May 12, 2015 | 08:19 PM
giiventofly's Avatar
Default Slow h/c 2500hd
05 2500hd, 212/218 cam, stock 243 heads, 8.1 injectors, e fans, stock everything else (including manifolds).
35's and 4.10s put it going through the traps in 2nd gear.
Stock engine same everything else I was running 16.7s on a warmer day so it was a pretty decent gain. However running 15.4s and watching stock turbo diesels clip off low 12s was pretty lame.
Old May 12, 2015 | 08:38 PM
07bluelbz's Avatar
There is no stock turbo diesel that will run 12s.
Old May 12, 2015 | 09:51 PM
Maybe you misunderstood my post, because there are plenty of 12 second duramaxs still running the stock turbo, even stock injectors and cp3.
Old May 13, 2015 | 06:33 AM
07bluelbz's Avatar
I don't disagree with that statement so yes I guess I misunderstood your wording. 1,000 ft. Lbs of torque sure helps get those trucks moving and even on a duramax, you want the lightest wheels possible. Find some pyo's. They are really light. My Dmax went 13.1 on the stock trans.
Old May 13, 2015 | 10:06 AM
ZO6Ted's Avatar
Great time and mph for almost stock. I'd be proud of that!
Old May 14, 2015 | 04:18 AM
Fast_six oh's Avatar
I went 14.99 on 33s before all my mods..had traction issues at the light as well..your tires are holding you back big time..some longtubes and a re-tune should make a very noticeable difference..at least they did on my vmax..
Old May 14, 2015 | 05:41 PM
10 Second Club
4.56 or 4.88 gears.
Old May 15, 2015 | 01:09 AM
This is my new best from tonight after the longtubes and blackbear tune..the weather only dropped to about 70 degrees..i think with cooler weather it would have a been better..stock cam, stock stall
Attached Thumbnails Slow h/c 2500hd-1431670219044.jpg
Old May 15, 2015 | 01:16 AM
Next time you run, try to step down to a smaller tire like a 265, 285 of some sort..should be worth a few tenths
flatblack83
Jan 3, 2026 07:10 PM
BlownHD
Oct 3, 2015 12:24 PM
Cammed4ever
Sep 30, 2015 03:38 PM
69z-28
Sep 21, 2015 07:31 AM
zblee
Sep 17, 2015 07:58 AM
