Shock options for 4wd launches
Tim- there not that bad. Check out my old thread.Also I've seen a few duramaxes running the QA1 fronts, have you read much about those set ups ?
https://www.performancetrucks.net/fo...ed-nbs-497741/
I have wanted to try the straps for a while but I'm still rocking the chains. I have mine set so they pre load the front suspension by about 1/4 inch when chained down. It has completely gotten rid of any lift and the hop. I don't think shocks will do what you need on your truck. You will probably gain more from straps that will actually pre load the front a little. I couldn't believe how smooth my truck felt launching at 12psi with the chains and et streets. 1.45 60' feels awesome in these big trucks. LOL
With cranked keys my dmax went thru 4 tie rods , after the lift I made sure I kept the front angles flat , and it launches nice now.
My black truck launches awesome for crappy shocks and no straps , my cv angles are straight to slightly angled down , so when I launch they don't angle up too bad , and I 1.6 consistently , I'm going to do straps as I hear they really help like others have said .
Try de cranking a bit and see if it helps , then try the limiting straps , I bet between those two things your launch will be better.
Also one other thought , have you tried to use stock size tires just for comparison ?
Your making good power and seeing the problems that come along with it LOL !
I assure you 1.45 is possible. The last time I was at the track I had 8 runs at 1.50 or lower. Pre loading mine made a huge difference. If I give it even an inch of travel it would start to hop around. It was holding 10psi launches all day. I tried one 12+psi launch and it started hopping the front left tire. LOL
zblee
Nov 11, 2015 12:41 AM
bluestang50
Sep 21, 2015 08:36 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
