TIME SLIP DATABASE
Shock options for 4wd launches
Old Jan 7, 2013 | 06:23 AM
sharpshooter's Avatar
Tim- there not that bad. Check out my old thread.Also I've seen a few duramaxes running the QA1 fronts, have you read much about those set ups ?
https://www.performancetrucks.net/fo...ed-nbs-497741/
Old Jan 9, 2013 | 10:43 AM
2ktransam's Avatar
I have wanted to try the straps for a while but I'm still rocking the chains. I have mine set so they pre load the front suspension by about 1/4 inch when chained down. It has completely gotten rid of any lift and the hop. I don't think shocks will do what you need on your truck. You will probably gain more from straps that will actually pre load the front a little. I couldn't believe how smooth my truck felt launching at 12psi with the chains and et streets. 1.45 60' feels awesome in these big trucks. LOL
Old Jan 9, 2013 | 05:57 PM
Beatdown Z's Avatar
Laid Back
1.45!!! I didn't even know that was possible in a 4x4 ext cab. Preloading the chains/straps does help A LOT. My truck rode like crap with my chains tight, but it did launch nice...
Old Jan 9, 2013 | 06:18 PM
TIM Z's Avatar
11 sec. Truck Mod
No bud I haven't read up on that . But I should
With cranked keys my dmax went thru 4 tie rods , after the lift I made sure I kept the front angles flat , and it launches nice now.
My black truck launches awesome for crappy shocks and no straps , my cv angles are straight to slightly angled down , so when I launch they don't angle up too bad , and I 1.6 consistently , I'm going to do straps as I hear they really help like others have said .
Try de cranking a bit and see if it helps , then try the limiting straps , I bet between those two things your launch will be better.
Also one other thought , have you tried to use stock size tires just for comparison ?
Your making good power and seeing the problems that come along with it LOL !
Old Jan 9, 2013 | 08:24 PM
2ktransam's Avatar
I assure you 1.45 is possible. The last time I was at the track I had 8 runs at 1.50 or lower. Pre loading mine made a huge difference. If I give it even an inch of travel it would start to hop around. It was holding 10psi launches all day. I tried one 12+psi launch and it started hopping the front left tire. LOL
walledition
Feb 24, 2026 03:27 PM
zblee
Nov 11, 2015 12:41 AM
bluestang50
Sep 21, 2015 08:36 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
pewter00
Sep 11, 2015 09:32 AM
