TIME SLIP DATABASE
New PB
Old May 28, 2013 | 10:30 PM
Steve Sr.'s Avatar
Default New PB
Well starting this race season out pretty good.Over the winter had my 317 heads ported and 2 bent valves replaced along with a performance valve job. A Super Victor Jr . replaced the performer manifold.
Thinking I need to change jets since I've got all that new air flow. Went from 76 primary and 86 secondary to 82 and 92. Plugs looked lean but it wouldn't run any better.
Got it to the dyno with a AFR meter and found out I was way to rich. Took carb off 4 times going smaller each time until it was 12.8 -13.2 to 1 and was really responsive.
NA was 432 HP and 545 ft lbs torque. With 250 shot was 606 HP at around 5400 rpm. Was 875 ft lbs at 3400 rpm. This all at the ground.
Ran a 10.57 with all 250 off the line. ran 10.54 @ 128mph with 200 off the line and the other 50 coming in at 1 second.Thinking it should be closer to 10.40's. Working on that now.
Hope everyone is having a great time at the track.
Old May 29, 2013 | 03:07 AM
oakley6575's Avatar
Holy ******* torque!!
What are the cam specs? It sure likes the juice.
Old May 29, 2013 | 03:22 AM
ak2007r6's Avatar
+1 to the torque numbers. holy ****.
Nice times!
Old May 29, 2013 | 07:08 AM
pittman's Avatar
Damn Damn Damn thats good !!! Congrats Steve, you earned evey thenth of that !!!!!!!!!!!
Old May 29, 2013 | 05:19 PM
black00chev's Avatar
Slowest turbo build ever!
Wow thats awesome man! Glad to see the carb setup is working well for you.
Old May 29, 2013 | 06:17 PM
Steve Sr.'s Avatar
Thanks guys, was told by my cam guy that an LS on juice really puts out the torque. Am putting a set of 3.89's in now. should help top side of the 1/4 where my power was dropping off. Also looking into a cam with more duration. I'm 5.4 tenths away from 9.90's. Look out here I come.............
Old May 29, 2013 | 06:20 PM
Steve Sr.'s Avatar
Thanks Bob, My wife said I could come back in from the barn when I hit 9.90's. That as much money as I've spent I should be in the 9's.lol
Old May 29, 2013 | 07:55 PM
oakley6575's Avatar
Are you still running the 224 comp cam?
Old May 29, 2013 | 09:13 PM
Steve Sr.'s Avatar
Well kinda,lol. I sent that cam to schidner cams in California and had it reground to 238/248 dur and 595/612 lift. Now I'm looking at getting a new cam. Not sure what specs yet ,but same lift with more duration.
Old May 30, 2013 | 02:04 AM
jmgak47's Avatar
Congrats on the new PB! Have the truck running great! What RPM you crossing the traps at? Not understanding the gear change. If you have more gear to go in the 1:1 give it more gearing, a larger camshaft and/or a looser stall. That will take care of the problem. You have TQ and lots of it, use it to get you off the line fast and moving the rest will take care of itself.
