TIME SLIP DATABASE
Into the 13s
Old Apr 4, 2010 | 09:17 PM
  #121
GMCtrk's Avatar
Not sure why everything thinks I have cats. It's a 3" off road pipe into the stock catback.
Anyways, I don't know why it isn't locking up because I can manually command lockup with my bidirectional controls on EFI live. So for some reason the PCM isn't commanding lockup. It will lockup like 2-3 minutes after you've been cruising on the highway.
As well, Krambo's idle sticky is pretty decent considering it's generic. It starts up good now and hold idle, but it's bad when coming to stops, it wants to die. So I'll need to work on that.
Old Apr 4, 2010 | 09:18 PM
  #122
00ChevyScott's Avatar
Wearin' da big hat
Getting any missfires? They unlock the torque converter and will cause it not to lock
Old Apr 4, 2010 | 09:20 PM
  #123
GMCtrk's Avatar
Yeah I had the SES light flashing but I just turned it off. I think you may be up to something there.
Aren't false misfire codes common with cam swaps? I'll bump up the misfire minimum RPM threshold and see if that does the trick. I'll try and get an idle vid tomorrow too.
Old Apr 4, 2010 | 09:40 PM
  #124
budhayes3's Avatar
PT's Slowest Truck
+1, this is what I was going to post up, I'll bet that the PCM is detecting misfires, which may be false due to the cam
Old Apr 5, 2010 | 12:22 AM
  #125
Spoolin's Avatar
GFYS and STFU
Never knew that! So you ARE just more than a pretty face!! Who'da thunk it!
Old Apr 5, 2010 | 12:57 AM
  #126
fastnblu's Avatar
If the tq.conv. won't lock cause it detects misfires, after a cam swap, if that's what happening, what's the cure?
Done thru tranny tables or somewhere else in tuning? Or both?
Old Apr 5, 2010 | 10:50 AM
  #127
dlt76028's Avatar
C5621-C5627 set all to 32767 that will stop misfires.
Old Apr 5, 2010 | 11:15 AM
  #128
fastrt's Avatar
11 Second Truck Club
sorry jeezz, when you say catback it usually means it is behind the cat.
yeah what he said
Old Apr 5, 2010 | 12:23 PM
  #129
nonnieselman's Avatar
ill sell you a turbo/nitrous/methanol setup that will get you into the 11s..
Old Apr 5, 2010 | 12:58 PM
  #130
dlt76028's Avatar
Did you ever go 11's with it?
