TIME SLIP DATABASE
I think I broke into 12's..
Old Oct 30, 2006 | 08:25 PM
  #31
Rhino79's Avatar
9 Second Club
4.10's and a 26" tire is an effective ratio of 4.79!
Old Oct 30, 2006 | 08:30 PM
  #32
Sport Side's Avatar
Originally Posted by Rhino79
Yeah but then he wouldn't be "Cam Only". He drive this truck very very little and has another vehicle, More stall will give it what it needs.
Oh, **** street-ability then.
I wanna show you guys this. If that's the cam, his torque curve will look like the following. How do I know? Because 3/4th of single pattern cams with 4* of advance look like this!
Check out the blue line. Oh.. Thanks Josh Luther! This is his 224/224-112+4 with XE-R lobes... Same cam, but 2* smaller than Tans. What's wrong with this torque curve? Precisely nothing, except we're talking about 4000LB trucks with 3000 rpm converters (2600 for Tan)... A slowly climbing torque curve is great, but what about one like this...
Can you see this difference? Lets assume that both cams are making the same amount of peak HP and peak TQ. We'll use Josh's dyno and say 335FT LBS and 335HP. The only difference is the other cam makes 335LBS way before peak torque for these motors (4800 RPM). The sooner you make torque, the harder Tanz truck is gonna come off the line.
Just shows how important the head/cam choice is. Who knows? He may be deep in the 12s with 15-25 more FT LBs 1000rpm sooner, ya know?
Old Oct 30, 2006 | 08:34 PM
  #33
Tan327's Avatar
I didn't know my cam was advanced 4*? I thought it was just 226/226 .585 .585 112lsa
Old Oct 30, 2006 | 08:40 PM
  #34
Rhino79's Avatar
9 Second Club
Thats true, but do you not think it would be streetable with a 3800 or 4000 converter? Thats almost the default size for F-body guys with cammed motors. I know that trucks are a good bit heavier but wouldn't the driveability be similar with the F-body's?
Old Oct 30, 2006 | 08:41 PM
  #35
Rhino79's Avatar
9 Second Club
Most sinlge pattern LSx cams are cut with 4* already in it. At least thats what Comp told me.
Old Oct 30, 2006 | 08:42 PM
  #36
onebadrubi's Avatar
since they are lighter tho its eaiser to move with such a big converter tho, Is my understanding.....
I thought you advnaced thme when installed and lined up the dots on the timing gear/chain?
Old Oct 30, 2006 | 08:44 PM
  #37
Rhino79's Avatar
9 Second Club
You can further advance or retard them but they are built with advance in them.
Old Oct 30, 2006 | 08:48 PM
  #38
Sport Side's Avatar
Streetable, I don't know... Quicker? Yes.
Look at Josh's dyno... The further you move up RPM (until 4800), TQ increases. Pretty much, the bigger the converter, the quicker he will go.
With the 2nd dyno... You could very well come off the line just as hard with a 3500 converter as opposed to a 4500.
Old Oct 30, 2006 | 08:49 PM
  #39
onebadrubi's Avatar
ahhhh I had a college class today, without you guys the saying "you learn somethign new everyday" wouldnt work for me wiht yall....haha
Maybe I should start payin attention in college.
Old Oct 30, 2006 | 08:50 PM
  #40
onebadrubi's Avatar
Yes but if he flashes it TOO much wouldnt he be actually hurting his self I mean lets say he flashes at 4k-4200 and then that only leaves 600 rpms till its out of peak torque, Wouldnt it be better to amybe have close to a 1000rpms till you run out of peak torque?
