TIME SLIP DATABASE
Help me with my 60'
Old Apr 15, 2011 | 08:35 PM
JankesGTO's Avatar
Default Help me with my 60'
Ok background on the truck. stock 6.0 block 76mm turbo truck backed with 3200 yank and 4l80e 3.42 gear with 6" drop and caltracs and m/t 28 et street slick. best 60' I can get out of it is 1.74. Last weekend it was cutting 1.88 before blowing the tires off. zero preload on caltracs. Installed msd 2step today but I think this is only going to add to the blowing off of said tires, as I can now build damn near 10 lbs of boost at the line. Any suggestions on getting this thing to hook?
Old Apr 16, 2011 | 08:31 AM
blown02408's Avatar
02 w/ lowest mileage 2800
Shocks? Rear shock relocation helps a lot. have you tried a little more preload on the caltracs?
Old Apr 16, 2011 | 11:14 AM
pittman's Avatar
What was your tire pressure and what was the temp on the track ?
Old Apr 16, 2011 | 05:09 PM
JankesGTO's Avatar
20-22 tried 18 samething. Track temp have no idea. I'm going to play with caltracs this weekend.
Old Apr 16, 2011 | 09:18 PM
quicksilverado's Avatar
A true 10.5 slick and about 15 psi in the tires will do the job.
Old Apr 16, 2011 | 09:36 PM
Jake99's Avatar
or 12 psi. Thats what iv always done. and id try a set of shocks at 90-10 op front also.
Old Apr 16, 2011 | 09:44 PM
tarinitup's Avatar
9 Second Truck Club
Alot depends on track prep. Last week I was cutting 1.61s and last nightbest I hot was 1.81 and I have all the mods people have mentioned.
Old Apr 17, 2011 | 01:33 PM
sixltrbtr's Avatar
My best 60' so far is only a 1.70. That's with worn out shocks, the caltracks cranked pretty tight and 10psi on hoosier slicks (scary ride on the big end). I've heard of some cutting some 1.6x's. That might be the best we can do without getting more serious with the suspension (like drag shocks, ladder bars etc.).
Old Apr 17, 2011 | 01:53 PM
pittman's Avatar
I think Bluecajun is cutting 1.5 sixtys on regular suspension and caltracs ??
Old Apr 18, 2011 | 09:14 AM
JankesGTO's Avatar
If I could get a 1.6 60'ft I would be happy. What is the correct way to measure pinion angle on these rearends?
