Originally Posted by Atomic
(Post 5262906)
http://i11.photobucket.com/albums/a1...ps22d0b117.jpg
Turbo was a bw s482 and converter a low stall ptc 10.5" triple disc what are you gonna do with that hole in the fender and a PD blower? stick your air filter out it :cody: |
(Post 5262906)
Turbo was a bw s482 and converter a low stall ptc 10.5" triple disc |
(Post 5262921)
holy shit thats intense...
Ok so I went out and installed a bigger wastegate spring that allows me to build more than a 7psi launch...lucky I was 1/4mile from the house because I had to drive home in 4hi. Apparently I will need traction bars to launch on 13psi, because the rear springs wrapped and busted the rear universal joint. Luckily it barely smacked the gas tank and sheared 2 caps off the joint, the ds survived. Time for cal-tracs or Smith Racecraft! LOL!!
Originally Posted by 1969x11
(Post 5262796)
At what point do you need anymore than a strapped front end and a ride height that allows the cv's to be flat? This is all i have as of now and i can dead hook on street tires leaving on 7psi and ramping to 18psi.
The track manager(in my case track owner) was not impressed or happy about it. With straps & CalTracs, and drag radials, I could still have some tire spin on the launch, but it became manageable. |
Before I strapped the front it would buck a little and pull hard left. The straps fixed that problem but my truck was lazy to build boost with the 5lb spring in the gate. With the 9lb spring the boost comes on violently and this morning was the first time I have tried to launch over 8psi. I think I'm gonna go with the Assassin bars and some adjustable rear shocks
Bringing this back up...I got my bars put on and adjusted. Now I spin for about 20 foot and it finally hooks(street tires) LOL!! Now I need a $1200 set of drag radials. Does everyone recommend the M&H 275/50/17's ??
I prefer the MT ET street radials over the M&H (which tend to run small)
Originally Posted by GMCtrk
(Post 5270077)
I used to use that size m&h, they worked pretty good! Very soft though, maybe 10k street miles tops.
