TIME SLIP DATABASE
first time to the track
Old Mar 4, 2013 | 06:27 PM
  #41
durty's Avatar
has a 275/45-20
Old Mar 5, 2013 | 03:33 PM
  #42
hog's Avatar
hog
i would leave in third and then pull it down into 2nd after it shifted the 1-2..
Then run it out to the rev limiter and see how it does.
If you are wanting to go through the traps in 2nd, this advice is key. If not you are launching starting in 2nd gear until your TPS reads over 87.5% on the GMT800 4l60e/65e trucks.
Probably not much of a difference as most people do a WOT stomp of the pedal, but if you try and walk it out at les than 87.5% the trans will be in 2nd.
peace
Hog
Old Mar 5, 2013 | 03:38 PM
  #43
hog's Avatar
hog
Oops, thats over 81% TPS on the 05-07, not 87.5%.
And it appears that the WOT upshift occurs 2-3 mph higher when the shifter is in D or OD than when the shifter is left in 2nd..
peace
Hog
Old Mar 15, 2013 | 03:32 PM
  #44
durty's Avatar
little update on this, had my buddy look the tune over last night, its almost perfect, its 11.78:1 at WOT, the long term fuel trims are 0-2%, no torque management, only thing he fixed was the speedo, he has the unlimited tuning on 99 model years on his HPtuners, so it cost me $20.
it did have timing retard at higher RPMs under a load, 8-10 degrees on 87 octane, i put 91 octane in it, runs alot better and pulls harder in the upper RPMs.
ARC
57
Feb 21, 2022 10:54 AM
GMCtrk
Jul 17, 2015 06:39 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
coryhussey
Jul 6, 2015 10:23 PM
