TIME SLIP DATABASE
First time back at the track in a few months and was pretty nice
Old Nov 26, 2009 | 12:05 PM
  #21
litreddevil's Avatar
Banned
i would just get the heads done you can get alot out of them raise the compression,and porting=alot.if i remember right you are under 11;1 compression.put that to high 11's and do the port work to the runners and put a bigger cam you would be adding weight to slow it down.with the short block you have.
you have a good short block just need to top it off with completed stuff not just i'll settle stuff.
i bet you have a good 5 tenths in her with finishing the top off right.
Old Nov 26, 2009 | 12:14 PM
  #22
12sec.5.3's Avatar
The heads are stage 2 hand ported by Pete. Compression is around 10.25. I'd like more now... Bigger cam could be in store bc I can barely hear this one so I can def go bigger there. Might consider porting the intake a bit if it's worth it.
Old Nov 29, 2009 | 11:02 PM
  #23
sprayed99's Avatar
Porting the intake is a total waste of money and time...
see for yourself...
http://www.hardcorels1.com/vbulletin...ead.php?t=3833
ARC
57
Feb 21, 2022 10:54 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Cowboy17
Jul 9, 2015 08:22 PM
