TIME SLIP DATABASE
first LS lifted truck in the 11's
Old Nov 29, 2014 | 01:42 PM
ILWALKU's Avatar
Registered User
Default first LS lifted truck in the 11's
Here's a few pic from today. Truck ran as seen in pic.
Attached Thumbnails first LS lifted truck in the 11's-1417289963212-267113921.jpg   first LS lifted truck in the 11's-1417290002465-493782966.jpg
Old Nov 29, 2014 | 09:48 PM
brent1976's Avatar
11 Second Club
Sorry, but you're not the first.
Old Nov 29, 2014 | 09:57 PM
Vortec350ss's Avatar
Still an awesome time and a really bad *** truck!
What's next? I vote meth and more boost!
Old Nov 29, 2014 | 11:07 PM
sharpshooter's Avatar
Vortec350ss - this is sureshot's old truck - it's on meth and about 16 #'s of boost. It's the same set up as mine but I haven't had mine at the track with it's current set up to see what it would do. So the new owner (ilwalku) ran his to find out. I think the next mod will be a converter. We are running stock converters right now. His new wheels and tires weigh 92 pounds a piece so we were real happy to run an 11.9
Also who has ran an 11 second pass or faster with a lifted gas LS based truck? I thought 12.0 was the fastest.
Old Nov 30, 2014 | 12:03 AM
George C....'s Avatar
Formerly ScreamingL
what head unit?
what heads?
what cam?
Old Nov 30, 2014 | 05:31 AM
ScreamingL
D1SC
Stock 317's
Vinci trucker cam 216/224 .551 .551 lsa 115
It's the exact same build as my signature. The only difference is it has a big red bypass and I run a tial.
My track time in my sig. was 3 years ago on lower boost and lower shift points. Now I'm going to run mine again. Lol
Old Nov 30, 2014 | 07:06 AM
ILWALKU's Avatar
Registered User
So who was? And what time did they run .. lifted LS based truck ?
Old Nov 30, 2014 | 10:39 AM
Formerly ScreamingL
Originally Posted by sharpshooter
ScreamingL
D1SC
Stock 317's
I need to get a converter then and see what my setup does. p1sc 5.3 on 12 psi trapped 113 @ 12.5 2010 lifted crewcab with a lazy 2.1 60'
Old Nov 30, 2014 | 09:18 PM
Yup I knew it was his old truck. Didn't realize you guys were already on meth! That's a lot of boost too lol.
Also, great 60' on the stock converter. A looser stall should make a great difference for you seeing as you build more boost with rpm. Not only will it cut your time a lot, but I bet mph increases as well. I gotta imagine those wheels are killin you... I thout you were running on the old combo.
Old Nov 30, 2014 | 09:25 PM
Also, what gears do you have? What rpm do you cross the line at? If you can make that closer to 6k at the finish it will pull a lot harder on the back half. Make 3rd gear work harder for you. Are you too proud to grab some different wheels and run a lighter drag tire? It would make a world of difference.
