TIME SLIP DATABASE
drag tire question
Old Oct 1, 2011 | 01:17 AM
  #21
Phantom's Avatar
11 Second Club
How fast you been skolman? I been high 9s on a et street and a radial front, no problem. Takes alot of work to make anything with any power work on a drag radial.
How fast have you been mr intelligent?
Old Oct 1, 2011 | 08:23 AM
  #22
skolman91's Avatar
Any tire manufacture or anybody with some sense will tell you not to mix bias rears with radial fronts. You even said a few posts up its a handfull.
My point was stopping telling someone that prob isnt making over 400hp to run a slick. You might want to wreck your "9sec" ride, but i doubt he wants to wreck his truck..
Old Oct 1, 2011 | 11:03 AM
  #23
Phantom's Avatar
11 Second Club
Tell ya what mr intelligent, if he can't handle a 13second ride on slicks, he has no business bein on the drag strip.
Next time you go to drag strip, look at how many "idiots" there are that run the same way. Do you go to the drag strip or do you just read manufactures suggestions on how it should be done?
Old Oct 1, 2011 | 03:19 PM
  #24
06Sierra2's Avatar
alot of interesting debating going on in here. im interested in this thread bc im looking for some sort of stickier, shorter tire to run at the track as well. this will be my first attempt at getting my truck to "hook" as low pro 22s dont quite get it done lol. also, i have a set of 16 stockers as well. sorry for the thread jack
Old Oct 2, 2011 | 10:55 AM
  #25
custm2500's Avatar
Ph.D. in HUBRIS
Originally Posted by skolman91
Please dont listen to these not too intelligent people telling you to run bias ply rears with radial fronts. Unless you are making some decent power a well setup drag radial will do fine..
It isn't recommended but I also run bias rears and radial fronts. It is more a cover there *** issue then anything else from the makers of the tires. Mixing on the same axle can cause some issues but front to back really has little effect on driveability. I do plan to get bias front runners but I have too much other stuff to spend $300-$400 on before I worry about them.
I haven't been terribly fast on my old set up but I have been just over a 100 with absolutely no sign of any issues from mixing tires. Next year I hope to have the truck back together and should run 11s or better on a 100 shot. I am sure after spending all the money I have I won't be buying bias tires for upfront right away and don't anticipate there being issues.
Radials are getting better but they are still best only if you are running in a class that requires a radial tire. Especially in a truck since we are fighting less then ideal weight balance already.
BoostedBowTie
Jan 3, 2020 06:46 PM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Austino
Jul 30, 2015 03:28 PM
