TIME SLIP DATABASE
Do I need tubes in my drag radials?
Old Jan 17, 2009 | 07:14 PM
RandomHero's Avatar
Default Do I need tubes in my drag radials?
I've heard mixed opinions on this matter. I just picked up some Mickey Thompson ET Streets brand new for $250 delivered. The only problem is that they're the tube style. I've heard people get by without using the tubes but I don't want to jeopardize anything. I've also heard the tube won't work with stock rims so that's another issue.
So if anyone has any input on the matter on if tubes are needed for my tires I sure would appreciate it.
Old Jan 17, 2009 | 07:32 PM
Deckhand's Avatar
Im not sure for your application, but I put tubes in my slicks and had to drill out the valve stem hole out bigger in my racing wheels in order for them to work. One thing I noticed, and it happens to many people running tubes, is that they will probably have a major imbalance while cruising at a steady or highway speeds. But this also depends on how big your tire/tube application is. Im running 30x14's, so its a pretty good size.
If its safe, I would not run them if you can get away with it. But like you mentioned, dont jeopardize anything if it boils down to it. Maybe try calling M/T and see what they suggest!
Good luck
Old Jan 17, 2009 | 07:34 PM
you dont have to run tubes with them put them on and have fun I have et streets and the m/t drag radials and dont run tubes in either.
Old Jan 17, 2009 | 07:35 PM
Mangled03gmc's Avatar
Baltimore Whore
+1
Old Jan 17, 2009 | 08:33 PM
pittman's Avatar
No tubes needed !!
Pitt
Old Jan 17, 2009 | 11:23 PM
ap2002's Avatar
no tubes!!! i have friends that have been running them for years without tubes... one of the best street tires out there aswell
Old Jan 18, 2009 | 12:16 PM
RandomHero's Avatar
sweet thanks guys. I figured for $200 they were a good deal. He drove an hour and a half to drop them off at my house so I gave him $250. Not too bad if you ask me. I'm excited
Old Jan 18, 2009 | 12:32 PM
i cut a 1.78 ,1.79 and 1.74 yesterday on a set of m/t drag radial 275 /40 /17 on stock
17" silverado rims.
Old Jan 18, 2009 | 01:00 PM
RandomHero's Avatar
17" silverado rims.
That's badass. I figure anything could be better than the 2.2s I was cutting with an open differential.
I now have the truetrac in and a set of airshocks and with the drag radials it should be a bit better.
Old Jan 18, 2009 | 01:04 PM
00Silv4.8's Avatar
on the subject what do you guys prefer? radials or slicks in relation to the rear end going boom?
kainzien
Nov 10, 2023 11:37 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
Chevy305
Sep 28, 2015 09:21 PM
Slammed silverado
Sep 28, 2015 06:14 PM
