TIME SLIP DATABASE
Disappointing Times!
Old Jul 6, 2012 | 09:01 PM
88bluchevy's Avatar
my shift points are at 6000. I run an open 1'' spacer and I have considered sending converter back off to have it reflashed. Camshaft was installed straight up. What would be a good long tube header thesince hedmans are restrictive. And timing is set at 35 degrees. Thanks
Old Jul 6, 2012 | 09:27 PM
ZO6Ted's Avatar
Well for starters use some online weather station software to compare approximate conditions for your times. There are some links on here somewhere. It could give you some insight. Years ago I had 2 identical pickups except 1 was a Long Bed and the other was SB. The LB felt stronger with a comp 280 cam than the SB with the comp 270 cam. It would pull it in a roll. Ironically at our local 1/8 mi. track the SB would pull it .2 sec. The smaller cam won every time. Maybe you need more converter as well.
Old Jul 7, 2012 | 01:13 PM
YenkoST's Avatar
With that 2.48 gear from the TH400....you definately need more converter...3600 would definately help get it moving off the line better. As far as the headers, I would look into the Hooker SuperComps or something that yield a 3" collector and 1 5/8" or 1 3/4" primaries but more importantly clears the entire exhaust port. Secondly, with that camshaft, I would expect it to peak in power about 6000-6100 rpms. So, the shift points probably need to come up. I would try shifting at 6300-6500 rpms. Such as 6500 on the 1-2 and 6300 on the 2-3...might help as well.
Old Jul 8, 2012 | 02:47 AM
Vortec350ss's Avatar
Were you spinning out of the hole? If not then I think you'll be amazed at what a better stall and exhaust change will do for you. LT's will really open up the high end, and the stall will only help that cause as well.
I would look for a 1 3/4 primary with that size stall and cam with aftermarket heads. I also agree that your 6k shift point sounds too low. I know the LS engines are a different ball game... but I'm running a 222/226 and I'm reving mine to 6300 in a 6.0.
Old Jul 8, 2012 | 10:14 AM
88bluchevy's Avatar
Yeah it was spinning every launch. With the old setup it dead hooked and seemed to pull harder. Ill try a different stall and see if that helps. A head change is also coming soon.
Old Jul 8, 2012 | 02:57 PM
YenkoST's Avatar
Might want to get it to hook before changing anything but the stall definately needs to be a bit higher to yield the best times and increase the rpms for shift points. What heads are you switching too...that could also change the setup.
Another question, do you have a cross over for your duals like an X pipe?
Old Jul 8, 2012 | 03:15 PM
88bluchevy's Avatar
No its just straight duals. I would like to have an x pipe or h pipe. Heads will either afr or trick flow
Old Jul 8, 2012 | 05:14 PM
YenkoST's Avatar
The AFR or trickflow heads will definately need the 1 3/4" pipe to clear the exhaust ports. I have AFRs as well and a 1 5/8" tube won't clear the square ports.
As far as exhaust, you need an X-pipe to help the top end of the engine scavange the other banks of the engine better which would definately help on the top end.
Zizzle
Oct 19, 2017 08:44 PM
kr1s
Aug 24, 2015 05:34 PM
black03rcsb
13
Aug 13, 2015 04:05 PM
mr03silverado
Aug 13, 2015 11:40 AM
OLD BULL
Aug 1, 2015 05:00 PM
