TIME SLIP DATABASE
Rear mount set up times.
Old Jul 9, 2012 | 05:33 PM
03LQ9's Avatar
Default Rear mount set up times.
I decided to run my truck at the track for the heck of it even though it still doesn't have a locked rear end or drag tires....
The truck has 3.42 gears, 4l80e with stock converter, LQ9 6.0l, 212/218 comp cam, and a rear mount turbo set up, no intercooler and running on e85. It weighed in at 4950 with me in it at the track.
First run was 4.5 psi 13* timing
60' 2.334
1/8 9.080 @ 85.16
1/4 13.638 @ 107.40
Last run with 5psi and 18* of timing
60' 2.252
1/8 8.742 @ 87.49
1/4 13.17 @ 110.14 mph
Kind of hard to launch on a peg leg, LOL. Next time back it will have traction and be running around 10psi or so.
Old Jul 9, 2012 | 06:01 PM
quicksilverado's Avatar
Put slicks on it and crank up the boost. I went 11.35 at 118 with a 370, no IC at 12 psi and 12 degrees of timing Set up was nearly identical to yours. Damn that was about 6-7 years ago.
Old Jul 9, 2012 | 06:27 PM
ZO6Ted's Avatar
Get ready for some low 12s next time out. Then...
Old Jul 9, 2012 | 07:44 PM
03regcab sierra's Avatar
That 110mph trap speed is good for mid 12s. Get some slicks maybe a stall. Good numbers on such low boost though
Old Jul 9, 2012 | 07:55 PM
lglowe's Avatar
Is this an extended cab? Is seems to have a lot of potential. Slicks, good diff, and leave on boost next time and you have low 12s. Stall and more boost 11s easy I'd say
Old Jul 9, 2012 | 10:03 PM
03LQ9's Avatar
Its a regular cab long box truck. I ran it with a full 34 gallons of e85, even put some extra weight in it to help with traction. I should be able to take out 300-400lbs for next time with slicks.
I'm not sure if it will need a stall ? With negative timing it will foot brake 5 lbs on the stock converter.
Steve-O-08
Apr 19, 2018 09:32 AM
1bad2k
Aug 18, 2015 09:50 PM
Ketis
Jul 23, 2015 12:37 PM
Mike454SS
Jul 20, 2015 08:52 PM
black6spdz
Jul 16, 2015 01:32 AM
