TIME SLIP DATABASE
Disappointing numbers
Old Jan 20, 2007 | 11:39 PM
thunder550's Avatar
High on diesel fumes
Default Disappointing numbers
Took the truck out today, ran a best of 14.89 @ 97, with a 2.4 60'. I need some boost
This is with 30* of timing across the entire run.
Low compression N/A 408 has no *****!
Old Jan 20, 2007 | 11:44 PM
tarinitup's Avatar
9 Second Truck Club
I thought you were faster than that, before the 408. Put some nitrous on it to hold you up until you get some more boost.
Old Jan 20, 2007 | 11:47 PM
Rhino79's Avatar
9 Second Club
whats your comp ratio?
gao8302's Avatar
what do you plan on going with for a turbo? Twin or single turbo?
Old Jan 21, 2007 | 12:07 AM
thunder550's Avatar
I was at a 13.66 @ 104 before
9.5:1 SCR, 7.5:1 DCR
Single, probably a pt-88 or something similar.
Old Jan 21, 2007 | 12:10 AM
Rhino79's Avatar
9 Second Club
Somethings not quite right, you've got a good setup and should be at least low-mid 13's NA right now. What does the converter flash too?
Old Jan 21, 2007 | 01:19 AM
99Silverado5.3's Avatar
get that thing on the dyno
Old Jan 21, 2007 | 03:41 AM
thunder550's Avatar
It doesn't really flash. I can stall it to about 2400, but if I just floor it from a stop it hits less than that.
Old Jan 21, 2007 | 03:49 AM
Mangled03gmc's Avatar
Baltimore Whore
something isn't rite ther, def should be faster then that..That set up should be good for mid 13's atleast na
Old Jan 21, 2007 | 04:04 AM
thunder550's Avatar
Oh, another fantastic piece of info. I burned 2 qts of oil in 1000 miles. I hope it's the PCV. My night was cut short when my Check Oil Level light came on.
