TIME SLIP DATABASE
Disappointing numbers
Old Jan 21, 2007 | 05:57 AM
Wilde Racing's Avatar
How do I change this text
Man, That sucks.... How many miles are on the 408?
Old Jan 21, 2007 | 08:29 AM
KySilverado's Avatar
Damn, that does suck... I'm no expert with fresh engines but the oil consumption... hopefully the pcv is to blame otherwise maybe the rings aren't seated well yet or worse. I also think its gonna be hard to make any power N/A with a 7.5 DCR.
Old Jan 21, 2007 | 10:19 AM
thunder550's Avatar
High on diesel fumes
I've got about 1500 miles on the motor now. I have a compression checker, been too lazy to use it yet. I need to get off my *** and do it. I have an LS6 valley cover on order, I think I need to make some kind of catch can in the meantime just to see what happens.
Old Jan 21, 2007 | 10:20 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Man I feel for you. Spend all that money, hard work, and something is off. I would have lost it by now, for sure.
I hope it's nothing serious and you get it figured out quick n' easy.
Old Jan 21, 2007 | 10:33 AM
thunder550's Avatar
Thanks man. I hope I get it figured out too. I'm hoping it's just cause of the low DCR numbers and a shitty PCV system.
Old Jan 21, 2007 | 11:53 AM
Mangled03gmc's Avatar
Baltimore Whore
Edit *I didn't see the 7.5 dcr, get a huffer on that pig
Old Jan 21, 2007 | 01:00 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Damn sounds like my problems all over again except the lack of performance thing. Check your heads too and make sure they arent puddling a **** loud of oil up in them, I think that was the problem of my oil consumption. Also get a leak down tester it will show you alot more about whats going on then a compression tester. IMO you still be seeing more perfomrance then that out of the motor but I havent a clue what it could be if all your tuning is right. Is it a dog just cruising around? Your DCR is really low but damn, you have a ton of cubes
Old Jan 21, 2007 | 04:29 PM
litreddevil's Avatar
Banned
dude you'll get it just walk away a little while then get back at it
Old Jan 21, 2007 | 09:18 PM
I have been trollling all your problem threads...wow...You need some good luck on your side.
Old Jan 21, 2007 | 09:34 PM
tarinitup's Avatar
9 Second Truck Club
I'm curious on how you can have the same compression on two engine but differenct DCR. How do you calculate DCR?
