TIME SLIP DATABASE
Disappointing numbers
Old Jan 22, 2007 | 12:15 AM
  #21
bad360rt's Avatar
11 Second Truck Club
Originally Posted by tarinitup
I'm curious on how you can have the same compression on two engine but differenct DCR. How do you calculate DCR?
Here's a good explanation of DCR:
http://www.empirenet.com/pkelley2/DynamicCR.html
And a calculator that will give you your DCR and your Boost CR:
http://www.rbracing-rsr.com/comprAdvHD.htm
Old Jan 22, 2007 | 12:36 AM
  #22
2004SSS's Avatar
wow i would have thought better #'s for that motor. i bet there is somethign not right though. that thing should have some torque to at least get you in the 13's imo.
Old Jan 22, 2007 | 09:30 AM
  #23
The Wood Hauler's Avatar
Wow, something isn't right, I think that's been established. My 408, even with stock iron heads, truck intake, a 2800 converter and 4.10's ran 7.8X's 1/8th mile naturally aspirated, which is around a 12.20 or so 1/4 you've got to have more in it. Granted i'm a rcsb 2wd but ****, 14.89 isn't right, I hope you get it figured out.
Old Jan 22, 2007 | 10:11 AM
  #24
thunder550's Avatar
High on diesel fumes
Well I'm pretty sure that my low DCR is to blame. I read the article posted above, and my DCR is actually about 7.02 according to that calculator. The article says that ideal is between 7.5 and 8.5. Knowing that makes me feel a lot better. A turbo should really wake this motor up.
I put the numbers into the other calculator linked above and got 6.77:1 DCR, corrected for altitude (1200 ft) and rod length. My dynamic stroke length is 2.83", so I'm losing a TON of the stroke length (and a TON of torque) due to timing events.
Putting 15 psi into the calculator gives me a DCR of 13.7:1, 20 psi gives me 16:1.
The good news is that I think I'll be able to run somewhere between 15 and 20 psi every day on pump gas. The bad news is that I am impatient.
nabozny21
Oct 17, 2015 07:47 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Slammed silverado
Sep 28, 2015 06:14 PM
g6t6o
Sep 26, 2015 10:57 AM
whitelazer
Sep 22, 2015 09:38 PM
