TIME SLIP DATABASE
Detroit Locker
Old Sep 3, 2013 | 05:33 PM
dick_landy's Avatar
Default Detroit Locker
Who's sporting a Detroit Locker at the track? What kind of power can they take?
I've gone through 2 Yukon Duragrips (Eaton Posi) already. The first one had the 400 lb springs in it and maybe 3500km on it, the second maybe had 500km on it and the 800 lb springs in it. The spiders and side gears just aren't strong enough, I broke 15 teeth of the side gears last Saturday at the track. I have a 30 spline 8.6" 10 bolt and I'm trying to decide what the best solution is as I'd like to keep the ABS and Stabilitrak.
Old Sep 3, 2013 | 06:22 PM
Dezert1500's Avatar
400rwhp N/A reg cab 12.3@108 with around 100 passes on a detroit not one issue.
Old Sep 3, 2013 | 07:14 PM
custm2500's Avatar
Ph.D. in HUBRIS
Why don't you look into a 14 bolt swap? I personaly would put my money on a stock 14 bolt over a 10 bolt anything. If you pop the 14 diff down the road then upgrade and you are bullit proof. If the stock holds for the life of the truck then you are event better off!
Old Sep 3, 2013 | 08:12 PM
dick_landy's Avatar
Because I'd like to keep my 15" rims and not carry the extra weight of the 14 bolt. It may be an option I'll go with but for the mean time I'd like to stick with the 10 bolt.
Old Sep 3, 2013 | 10:15 PM
skeet's Avatar
running a detroit true track, yukon axles 10:18's on a very small shot of nitrous had 4:88 gears now 4:56s been running same locker for a very long time without issues. yes its a stock 10 bolt this is my last mod i need then i'll be looking into a 9" which is planned out already just need to pay for it lol i'd just north of 600 rwhp
Old Sep 4, 2013 | 12:18 AM
AUTOT3K's Avatar
I dont really drag on mine but I probly beat on it more then you would at the track
donuts, burnouts, daily driving etc etc.
mines held up great and I love it. I'll definitely put one in the next diff I do!
Old Sep 4, 2013 | 07:20 AM
pittman's Avatar
Dick,
I presume you saw this thread ?
https://www.performancetrucks.net/fo...advice-520655/
That is the only wear I saw and if you change the c-clips every once in awhile it should run for years. Some people must not get the same wear as I did...like Skeet above.
Old Sep 4, 2013 | 08:04 PM
blown02408's Avatar
02 w/ lowest mileage 2800
Detroit locker here, it has held 500 and 700 rwhp so far and a few 60 fts in the 1.5 range. The one advice I was given was to roll forward in a straight line to make sure the locker was fully engage before really laying into it or you could send parts flying.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Alco
Jul 20, 2016 04:53 PM
5.3Caprice
Nov 7, 2015 08:56 PM
97aztecgt
Sep 10, 2015 05:07 PM
greedygenius
Sep 3, 2015 06:51 AM
