TIME SLIP DATABASE
12.43 @ 110.5
Old Oct 17, 2010 | 04:11 PM
brent1976's Avatar
11 Second Club
Default 12.43 @ 110.5
Went to a t&t today. Went 13.7 the first run spinning. On the second run I was at 12psi in 4wd, and went the 12.43, never got to go at 16psi, because a guy broke at 60' and coasted all the way down the track leaking tranny fluid. I'm happy so far, just wanted to see what it would do at 16psi.
Old Oct 17, 2010 | 04:33 PM
iamkeniff's Avatar
sob.....i seen that 12.4 @ 110 i was like hmm what mods...then i seen turboed...ill never be able to drop .3 and gain 6mph with just a cam
Old Oct 17, 2010 | 05:16 PM
SincalT/A's Avatar
Seems like it should run better at 12#'s...You getin into boost on the line?
Old Oct 17, 2010 | 05:31 PM
iamkeniff's Avatar
probably not since he only has a 3000 converter. he may see 3-4psi
Old Oct 18, 2010 | 07:31 PM
brent1976's Avatar
11 Second Club
keniff is right, I just barely see boost. I need to start looking for a hydroboost, because my brakes will not hold it back. I also need to go get the tune finished, it is "safe" right now, needs more timing, and is a little rich.
Old Oct 19, 2010 | 09:47 AM
iamkeniff's Avatar
it needs a little of this and a little of that i love that its a safe tune and it went 12.4s @ 110 that's good times.
id love to see your truck with a boost built 3200 converter so it could leave on more boost.
Old Oct 19, 2010 | 04:45 PM
brent1976's Avatar
11 Second Club
My 60ft was only 2.009, but I jumped way out on the late 80s 5.0 with a cam in the next lane. I think if my brakes would hold better it would make a lot more boost. I only saw about 1-1.2psi before it started pushing.
Old Oct 19, 2010 | 04:58 PM
joeyc125's Avatar
11 Second Truck Club
yeah, you def need to figure that out with the brakes. I can build full boost (only 7lbs) with my vac brakes. I ran a 12.78 in my 5600lb cc like that in 4wd. My performabuild converter brake stalls around 3-3200. The holeshot makes a HUGE difference in your ET if you can get your 60ft down. Maybe check your vac. check valve on your brake booster and see if it functions correctly. My truck originally came with that stupid motor thing on the booster, no check valve. I couldn't make any boost like that on the line. I put a check valve from an 02 truck on there and now I can make 7 lbs.
Old Oct 19, 2010 | 05:43 PM
pittman's Avatar
Good run man. That mph will support a 12.0 et. My old motor went 12.0 @ 110 mph. What was your sixty foot...about 2.0 ?
Old Oct 19, 2010 | 06:02 PM
ZO6Ted's Avatar
Your truck is gonna fly when you get your 60 down, tune dialed and colder weather! Mid 11's could be just a few weeks away
