Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
injectors for dodge guys.
Old Oct 5, 2009 | 09:12 PM
TURBHOE's Avatar
Default injectors for dodge guys.
just thought i'd let you guys know that if you making power on a hemi motor and want injectors, its cheaper to just find some ls2 aftermarket injectors. you look up dodge hemi injectors and its almost impossible to find. but if you look up ls2 injectors you can find high flow ls2 injectors all day long. the plug and length are the same.
Old Oct 5, 2009 | 09:22 PM
skolman91's Avatar
if i rem correctly people were using srt-4 and some ford injectors for the next step up, u sure ls2's are gonna work?
Old Oct 5, 2009 | 10:04 PM
TURBHOE's Avatar
yep they us the uscar connector. we called a manufactor of injectors and they verified it for us today. so we got some 39lbhr ls2 style injectors.
Old Oct 6, 2009 | 01:02 PM
SRT10KLLR's Avatar
Former Vendor
When we started modding the Hemi's 4+ years ago we were using the Ford Cobra(Blue) 39# injectors on F/I applications then switched to the SRT-4 injectors. On N/A applications we used the SRT-8 injectors because there was no tuning so you couldn't go to big on injectors. I had some custom sets made for the guys that went to stroked 370, 383, 392 & 426 Hemi's. Again in the early days you could not just pop in bigger injectors because there was no tuning like EFI Live or HP Tunners on the Chevy's. Even now tuning is not as good as the LS engines.
The LS2 and LS7 injectors work too as they have the same EV-6(USCAR) connector but don't go to big. The stock 5.7 Hemi's come with 30# injectors at 58 PSI and the 6.1(SRT-8) Hemi's come with 35#s.
I have many sets from the stock size to 40 lbs/hr and up to 72 lbs/hr. I also have some used Stage 0 SRT-4 injectors that flow 50 lb/hr at 58 PSI if interested.
Old Oct 6, 2009 | 06:27 PM
FrostKing's Avatar
What are the stage 1 SRT-4 injectors rated at again.? (light blue)
Old Oct 6, 2009 | 08:55 PM
TURBHOE's Avatar
we were told the 6.1's were 30lbs. hptuners is about to release hopefully. KRC said he could tune for them. we went ls2 aftermarket injectors that flow 39lb at 43.5. this is for a 397 stroker.
Old Oct 8, 2009 | 11:42 AM
SRT10KLLR's Avatar
Former Vendor
You mean Black with a Blue tip?
Here are the ratings from Mopar:
Fuel Pressure_______________43.5 PSI____________58PSI
Stage 0 / Stock '03_________456cc/min__________527cc/min
Stage 1 / Stock '04_________499cc/min__________577cc/min
Stage 2 __________________590cc/min__________682cc/min
Stage 3 __________________622cc/min__________719cc/min*
The stage 3 injectors are the same as the stage 2 but with an adjustable fuel pressure regulator. If you divide the cc/min by 10.5 you get lbs/hr.
The 6.1(SRT-8) injectors flow about 30#'s at 43.5 PSI but about 35#'s at our 58 PSI.
BTW, the Ford Cobra(Blue Giants) injectors are rated 39 lbs/hr at 39.15 PSI but actually flow close to 42#'s or 50#'s in our trucks.
I have a built 392 Hemi(late model stroked 6.1L) but need to find something to put it in, lol.
Old Oct 8, 2009 | 12:12 PM
TURBHOE's Avatar
i don't think these 39er's are ford injectors. maybe they are but they are made by some weird named company. i'll get the name from the guy. they are a touch shorter than regular long injectors. either way you go with changing injectors they have to be tuned so we figured we would get what was actually needed and not go with something that will be at 90+% duty cycle.
what is the stroke on a 6.1 392 motor? cause the bore on your motor is already bigger than on the 5.7 and the 4.080 crank with stoke 5.7 bore is 392. we are going .030 over i believe which gives us the 397.
Old Oct 8, 2009 | 08:14 PM
SRT10KLLR's Avatar
Former Vendor
The 392 has a 4.055 bore and 3.795 stroke. The engine builders I have talked to like the 370 for the 5.7 and the 392 for the 6.1 because of the rod/stroke ratio.
BTW, the 413 Hemi in the black truck in my sig has a 4.075 bore and 3.96 stroke.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
lxcoupe
Sep 2, 2015 12:58 AM
