Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
318 mods/lowering questions
Old Jul 1, 2010 | 09:22 PM
1logote's Avatar
Lts are better for torque and hp gain in the normal rpm range. Mid length or shortys are better for the high rpm range and/or ease of installation along with better ground clearance.
Old Jul 2, 2010 | 11:48 AM
lastrights's Avatar
i have the cherrybomb extreme its awesome ! you should get a magnaflow cat they make a good diffrence in exhaust also and give you some low grunt like 80 bucks , i had mienikie chop the stock off and put in the new one for like 50 bucks
Old Jul 3, 2010 | 03:17 PM
lastrights's Avatar
here what the HS look like gave me great low end ! !
this is the throttle body also
Old Aug 1, 2010 | 05:33 PM
JoeGibbSilverado's Avatar
good exhaust will go along way with a magnum engine. i had a 95 ram ext cab with 5.9 and 3.55s, bone stock it ran 16.4ish...ran true duals dumped before the rearend, with no cats, and took the airbox off at the track, resulting in a 15.9, not to bad of a gain considering what i did, good luck
Old Aug 9, 2010 | 07:46 PM
HemiLonestar's Avatar
Honestly, a mid mileage 360 would be worth it, it's a bolt in and instant power. I swapped a 360 in place of a 318 in a 72 Charger years back and made it a noticeable difference.
Old Sep 4, 2010 | 03:12 PM
Mopar also has a factory upgrade PCM for at least the 5.9 trucks, dunno about the 5.2's.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
JordanH
Dec 25, 2015 08:32 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
