banks boost gauge
Old Oct 24, 2007 | 03:24 PM
houhjc's Avatar
Registered User
Default banks boost gauge
I just installed my new Banks boost gauge on my stock 05 cummins 24 valve. I drilled and tapped my intake right before the head, and believe it or not, no boost recorded. At a high rpm, say 2000, maybe 2 lbs. Surely thats not normal for a stock engine. What should I expect, or where should I be getting my reading from?
Old Oct 24, 2007 | 04:18 PM
explorer5.0's Avatar
TOTM: November '07
you should see boost anywhere after the compressor. If you are just seeing 2psi, something is wrong.
Old Nov 2, 2007 | 09:46 PM
TchargedLS1TA's Avatar
Probably kinked you nylon line. Its a common thing when running it through the firewall. When they send you the line, its rolled up and can easily kink if you do not un wind it carefully.
Old Apr 17, 2008 | 05:13 AM
overdrive's Avatar
Is that 2k rpm sitting in the driveway, or on the street? You won't build boost untill you have a load on the engine while driving. Might check the compression fittings at each end and make sure you didn't overtighten them and crimp the tubing closed.
Randy
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
