msd 6010 tuning
Old May 28, 2012 | 08:07 PM
06murder's Avatar
Default msd 6010 tuning
Guys that's running 6010 how timing y'all running and what plug y'all running. I have tr5 in for now. But there the wrong ones for carb
Old May 28, 2012 | 08:12 PM
Phantom's Avatar
11 Second Club
What's your setup?
I started at 30* locked out from 750rpm and up
Old May 28, 2012 | 08:17 PM
06murder's Avatar
Haven't hooked the laptop up to it yet been to busy...but I looked at the paper work for it the other day it saids use non- resistor plug. I can't fine any
Old May 29, 2012 | 10:24 AM
TXsilverado's Avatar
wish i could help. i'll be playing with the 6010/6012 tuning here soon. can't wait! from what i've READ (not experienced) guys just tend to set the idle timing in to where it idles best, then ramps it anywyere from 29-36* of timing by 1800-2000 rpm. simple enough! some trucks will idle best with 20* others will idle better with 30*. just give the motor what it wants.
as for the starting range i also think you want to play with it depending on the combo. start at really low timing and ramp it to your idle rpm/timing. LS1tech has a carb section with some good stickies. phantom is a good source too
Old May 29, 2012 | 06:30 PM
06murder's Avatar
I have to get a better carbon for it then I play with it more that volley piece of **** have isn't cutting it...thinking bout the eldebrock 800 what y'all think?
Old May 29, 2012 | 06:31 PM
06murder's Avatar
Holley...sorry im the phone
Phantom's Avatar
11 Second Club
If you're calling a holley a POS and going to fix it with an eldebrock, I would suggest you do lots more reading.
Old May 29, 2012 | 07:57 PM
06murder's Avatar
Calling the one I have a pos....the two I been looking at is 750 chokeless dp or 800 eldebroke. Here in Georgia whether anit to bad
GXPJAY
Feb 13, 2022 08:15 AM
Silveradorst07
Dec 31, 2015 12:04 AM
bighouse
Aug 14, 2015 08:00 AM
Ammadien
Jul 22, 2015 08:50 PM
