Information on 88-98 frames offsets.
this is JUST a thought...what if you was to space the motor mount up say 3/8"-1/2" you think that'd be enough to allow you to put them in? i dont want to go that route but IF you have to i would try it. unless you want to notch the frame and just box it back in.
They have had some problems with fitment issues with the Super Comps...not the first I've heard of this.
Only way to get them in from my experience is from the bottom of the truck and you need to remove the starter, etc for them to slide up in there.
new infor... here is a Photo of the headmen headers i Have and a photo 0f the hookers i want to install. the headmen hit my frame where they go straight down and the hookers are curved in that area. Looks like the hooker will fix my problems
<<< Hooker"s
Notes
Exhaust Systems Can Also Be Fabricated Using Hooker Brand Mufflers
Will Fit w/Angle Plug Heads
This Header Is Equipped w/A Fitting To Accept The Stock Oxygen Sensor
Emissions Code 3-Amber; Legal Only For Off-Highway/Racing Use
<<< Headmen's
Notes
. Without smog injection or injection heads.
121. Must modify rotary A/C bracket.
127. Late model chassis. Engine offset to passenger side of vehicle.
212. Elite replacement gasket #27520.
225. Designed for use with a Trans-Dapt throttle body spacer.
45. Not legal for sale or use in California on pollution controlled motor vehicles.
6. Modification to stock exhaust required to retain catalytic converter.
B. Not applicable or intended for street or highway use. Legal only for racing vehicles which may never be used upon a highway, check footnotes also.
D. Not legal for sale or use in California.
<<< Hooker"sNotes
<<< Headmen'sNotes
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
