Information on 88-98 frames offsets.
I have a 1991 Chevy truck that I am in the process converting from a 4.3 to a 383…
My question is does anyone have any information on 88-98 chevy truck that move the motor to the passenger side from the factory. My 383 is setting more to one side and is the away to fix this problem. With the motor setting to the passenger side reg header will not fit.
Thank you for any help of links.
it should still fit if he is using the "stock manifold" and is using the 3 bolt frame mounts for the 350 and the clam shell mount on the block. i understand it being "offset" but it shouldnt be enough to stop you from bolting in the motor, and the LTs/Shortie headers if they are designed for your truck
Here a photo of my set-up... the headers are hitting where the frame rail turns by the starter area..
i called hooker today and they are telling me they never heard of any problem of the super comp headers in the C1500 truck... i guess i will try this and see what the out come is.
what motor mounts are you running? i cant really see them. did you try loosing your frame mounts an "lifting" the passenger side a little them try to fit the LT? i wish i could see it in person and itd be easier to determine the problem.
you used the stock 3 bolts in the frame right? you didnt redrill the frame to make the mounts work
they are stock frame and motor mounts. i can get the headers to bolt up loose. when you tight up the header bolts it twisted the header upwards. when this happen the mid-part of the header hits the frame where it dose the S(where the frame narrow) shape.
