guys that done the ls efi swap...little help please
Old Nov 27, 2012 | 09:17 PM
06murder's Avatar
Default guys that done the ls efi swap...little help please
Where to get the throttle cable from.I can't find nothing on throttle cable. And I have the the return style fuel rail. Do I need to get a regulator or what....
Old Nov 27, 2012 | 09:24 PM
SCOTT_A's Avatar
I used a throttle cable for a 96-98 vortec v8 truck. I bought it right from the local chevy dealer.
My 6.0 also has a return line, the pressure regulator is in the fuel rail. You just need to supply it with a high pressure line and then a return line to the tank.
Scott
Old Nov 27, 2012 | 09:44 PM
06murder's Avatar
Ok thanks man. You think that cable work on a 90mm the?
Old Nov 28, 2012 | 01:19 PM
Chevy-Fun's Avatar
Got my throttle cable from lokar. An pressure regulator is on driver side fuel rail if return style. After on check make sure fuel pressure is at 58# I believe.
Old Nov 28, 2012 | 07:51 PM
SCOTT_A's Avatar
Don't know man, Im using the stock TB for now.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
