guys that done the ls efi swap...little help please
Where to get the throttle cable from.I can't find nothing on throttle cable. And I have the the return style fuel rail. Do I need to get a regulator or what....
I used a throttle cable for a 96-98 vortec v8 truck. I bought it right from the local chevy dealer.
My 6.0 also has a return line, the pressure regulator is in the fuel rail. You just need to supply it with a high pressure line and then a return line to the tank. Scott |
Ok thanks man. You think that cable work on a 90mm the?
Got my throttle cable from lokar. An pressure regulator is on driver side fuel rail if return style. After on check make sure fuel pressure is at 58# I believe.
Originally Posted by 06murder
(Post 5030961)
