engine mount ?
Old Oct 6, 2009 | 11:40 PM
yaya's Avatar
Default engine mount ?
i have an 84 shortbed with a 305/350th & will be swapping to a 5.3/4l60e what motor mount plates can i use to keep the original driveshaft. i'm thinking i need the plates to set the motor back 1". Also i'm sending out my pcm to get programmed now i know i need to get the vats and rear O2 sensors removed is it anything else besides that and the tire and gear ratio size. The engine is out of a 04 suburban
Old Oct 21, 2009 | 06:39 PM
BOWTIEFREAK383's Avatar
I have an '87 and plan on the same swap. Anybody know?
Old Oct 23, 2009 | 05:20 AM
ChevyThunder17's Avatar
I believe I have the plates that set the engine back by 1". That should work. Someone that has actually done it would know better than I though.
Old Oct 23, 2009 | 12:17 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
There are a number of places/people that sell what you're looking for. BRP is where I bought mine from, but I mounted my motor forward. In any case, you can mount the 5.3/4L6xE combo to sit close to the firewall, and still use the stock shaft.... BUT.... you'll want to have that shaft checked to make sure it's still balanced, and can handle what you're planning in the LONG run.
Old Oct 23, 2009 | 12:19 PM
95ImpSS's Avatar
BTW... I (as well as a few others) have a build thread here with pics & all.
'86 Silvy (C10) - 5.3/4L65E - 4.10 w/ posi - Wheatley tuned..... now SOLD!
Good luck!
Old Oct 30, 2009 | 01:47 AM
12 Second Club
you will also want to remove any emissions from the tune unless you plan on reusing it.
Old Oct 31, 2009 | 09:41 PM
yaya's Avatar
update: well the motor and trans are in everything hooked up. Truck runs beautiful i have one problem now when i put it in gear it dies. I pulled dtcs and came up with p0740 and p0785. The engine and trans are out of a 2004 suburban, something tells me i didnt power up a wire
zblee
63
Jun 10, 2023 01:25 PM
Noah Burns
Sep 7, 2015 05:50 PM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
zblee
Aug 3, 2015 03:45 AM
