carb'd gen IV LY6 6.0L w/GMPP LSX/LS3 dual plane intake
#31
and still more -
current "temporary" gauge setup
twin electric fans -
hood on
side hole filled with welded in steel insert and a little filler and primer. just good enough to keep the inside clean and dry until paint and body happens.
new stance-
before I hid the wiring on the fender-
so its getting close! Not dialed in by any means...but its running and driving.
motor is thirsty...so my 750 HP Street needs a little tuning, got a small cooler for the trans
hood on
new stance-
#36
are those lower pressure (like in the 20's?) for the old tbi? are they return type or returnless? if you can regulate down to 7-10psi then I don't see why couldn't use it?
#39
that would do it. on the trucks harness...you'll use most of it for your normal hookups...starter, alternator, lights, etc...just delete things that aren't needed...emissions related?... as you go.
