Central & Northern ND, SD, NE, KS, OK, MN, IL, MO, IA, KY, OH, IN, MI, WI
Rotten Luck Road Damage
Old Feb 17, 2007 | 09:06 PM
  #41
CHEVRACER83's Avatar
lookin good bro.... hope the oil cooler lines work out
Old Feb 17, 2007 | 09:28 PM
  #42
truckmann's Avatar
Thanks! One way or another I will make them work.
Hopefully that will help my truck run a little cooler, the damn thing runs about 212* at idle and around 205* on the highway. I think my t-stat is a 187* I don't know if its worth getting a lower temp one or not, but I would like see my truck run about 10* cooler.
Old Feb 18, 2007 | 01:02 PM
  #43
lower temp thermostat will do no good unless you program your fans to turn on cooler... otherwise it will still get just as hot until the fans come on.
the larger radiator should definitely help with cooling...
but you need to know that these engines are made to run hot... it helps with fuel atomization/ emissions....
they are actually normal between 200-220
i know i freak out when i see it.. and i know this is the case... but its just the way theyre made
Old Feb 18, 2007 | 07:50 PM
  #44
Z284thgen's Avatar
11 Second Club
BB mod FTW
Old Feb 18, 2007 | 08:47 PM
  #45
truckmann's Avatar
Well I kind of figured a different stat woouldn't do much for it, which is why I didn't buy one. I guess what concerns me the most is getting my fans tuned properly so they are not running all the time. Of course I can't tell if they are acutually running when going down the road, but based on the temps they were set for, I think they may have been, so I turned the off/on temps up a little in the program. As long as it doesn't run any warmer when it gets hot outside I will be happy.
Old Feb 18, 2007 | 09:03 PM
  #46
truckmann's Avatar
Originally Posted by Z284thgen
BB mod FTW
I had to search for that one I hadn't seen it before. I may try that it looks easy and cheap enough!
Old Feb 18, 2007 | 10:00 PM
  #47
Z284thgen's Avatar
11 Second Club
i have stock T-stat if you wanna do it before hand and then just swap them out
i will have some prices tomm afternoon on the grille and stuff
Old Feb 18, 2007 | 10:10 PM
  #48
truckmann's Avatar
I think I will just do it to my stat. It is only about 3 months old as I replaced it with my water pump this summer when my gaskets started leaking. Heck for that matter I think I still have my old stock one too..
I hope they are good prices...
Old Feb 18, 2007 | 10:18 PM
  #49
truckmann's Avatar
I went to Perry and back today and man my gas milage sucks. I only got 15 mpg.
I got 18 mpg when I drove the truck back from Pennsylvania. Frank has been working on a tune for me that he might be able to get to me this week so hopfully that will help it run more efficienlty again. It would be nice to get it running the best I can before the OKC meet! I can't wait to get some headers on there and a good exhaust. Those old cats and stock exhaust can't be doing me any good.
Old Feb 19, 2007 | 03:56 PM
  #50
Z284thgen's Avatar
11 Second Club
oh to day was a flop didnt make it to the stealership but i will tomm as the SS goes in for some minor issues
