Towing-Supercharge or turbo my 6.0, or 8.1 swap?
Old Mar 29, 2011 | 10:52 PM
cvcook's Avatar
Default Towing-Supercharge or turbo my 6.0, or 8.1 swap?
Which would be best on my 03' 2500 HD for towing. doing a turbo, a supercharger,or an 8.1 swap?
Old Mar 29, 2011 | 10:55 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
How much weight are you going to tow, and how frequently?
Old Mar 30, 2011 | 12:51 AM
Mangled03gmc's Avatar
Baltimore Whore
A roots-screw style blower will be what your looking for.. Turbo's are great for it also, but you will need to build or size the turbo around your towing needs. A roots-screw, type blowe have the tq NOW..
Old Mar 30, 2011 | 07:05 AM
TIM Z's Avatar
11 sec. Truck Mod
Blower or Duramax swap.
Old Mar 30, 2011 | 08:00 AM
cvcook's Avatar
I tow daily around 6000#
Old Mar 30, 2011 | 08:27 AM
jpodell's Avatar
I tow with an 03 hd that has 8.1 and it can handle it with no problem. I'd prefer a diesel over the gas though. Don't guess it's an option for you though.
Old Mar 30, 2011 | 12:23 PM
I'd recommend a Magnacharger, keep the boost to around 6-7 psi, and run a conservative tune. Get yourself a boost/vacuum gauge so you can try to keep it in vacuum as much as possible for fuel economy. I'd also recommend upgrading your transmission cooler, and get a shift kit in that 4L80E. You'll like the results.
Old Apr 8, 2011 | 01:16 PM
Kerr's Avatar
if you tow daily id just trade on a new diesel.
If not, do some motor work on the 6.0L with a supercharger... The 8.1L is a good motor but its not all that if you go to mod them.
Old Apr 8, 2011 | 03:09 PM
GMC_DUDE's Avatar
A couple things to consider:
1: A 2003 6.0L is a Gen 3 "LS1-style" engine. An 8.1L is more like the old 454CID BBC. In other words, the swap may not be just an "unbolt the old, bolt in the new" job like replacing a 4.8 with a 6.0 is.
2: I have a Magnacharger on my 6.0 (used to be a 4.8) and the installation can easily be done in 1 day using ordinary garage tools.
3: I have had the Maggie for just shy of 7 years now, with a guesstimated 100K miles, and have had absolutely zero problems. I'm not sure too many turbo owners can say the same.
4; The 6.0 w/ Maggie will give you almost the same MPG as the 6.0 alone, as long as you stay out of boost. I understand the 8.1's are quite thirsty. With gas nearing $4/gal, this might be a consideration.
Old Apr 8, 2011 | 07:12 PM
Scott Mills's Avatar
I would have to add the my Magnacharger got me a little better gas milage than without.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Jake75
Jul 22, 2015 09:20 PM
Ammadien
Jul 22, 2015 08:50 PM
Cowboy17
Jul 9, 2015 06:18 PM
