New 90MM 8.1L Intake Manifold
Old Jan 6, 2015 | 07:37 PM
  #31
Whipped383's Avatar
Any updates? I'm also interested in a Whipple setup, I have a traditional Whipple kit that I'm hesitant on installing. I tow 13k and am at around 5000 feet in elevation so my 8.1 needs some help
Old Jan 6, 2015 | 09:52 PM
  #32
xx_ED_xx's Avatar
turbo boosting a stock intake with a mild port job would help more
  #33
xx_ED_xx's Avatar
then you will need pistons at least and fuel system upgrades including injectors
Old Jan 6, 2015 | 10:15 PM
  #34
Whipped383's Avatar
Not interested in turbos. Don't want the heat and I don't want to wait for them to spool. I really don't want much boost maybe 5 psi max just something to compensate for my elevation. I have a Whipple on my other truck and absolutely love the low end gains...at least for a small block
Old Jan 6, 2015 | 10:19 PM
  #35
xx_ED_xx's Avatar
trust me properly sized turbo you wont have an issue. heat if you wrap everything another non issue. turbos like heat to build power. over spinning that tiny 2.3 blower you will be making heat inside it which isnt helping at all on top of belt issues torsional load on crank etc plus the hp to turn the blower. From experience supercharged viper gts. 15 pounds of boost with a bigger then what you have blower 730 to the tires same engine with twins 1000 to the tires now i know you dont need that kind of power but which would you pick
Old Jan 7, 2015 | 08:16 PM
  #36
DEWFPO's Avatar
What are you going to be using/recommending for an intake tube/airbox. The OE one is too restrictive with the deep crease in it for the fan shroud and the sharp 90 degree bend.
DEWFPO
Old Jan 7, 2015 | 11:30 PM
  #37
Kerr's Avatar
Raylar is going to make me go broke lol. I keep adding to the want list
A small turbo would be a lot better than the whipple. Trust me j had both. But if you tow that much and ad any boost you have a hurt trans / converter. Besides the normal cold air intake, headers. I'd look into steeper gears or a under-over drive kit from gear vendors. If they make a under - over for you trans it would be best of both worlds. Incase you don't know how they work , they spit each gear somehow. So it would. " first under", stock first, first overdrive, second under. Second, second od, etc etc. At least that is how they explained it to me, I haven't had a under over. But I did have a over behind my TH400. It went. First, first over, second second over, 3ed. 3ed over. Split my gear changes in half. Helped a lot but it was on boarder line race car.
Old Jan 16, 2015 | 06:33 PM
  #38
Landon8.1's Avatar
Any word on when this is going to be available for purchase ?
Old Jan 16, 2015 | 07:31 PM
  #39
xx_ED_xx's Avatar
it isnt. it didnt make as much power as his other intake. I would love to throw some boost at it and see how it does
Old Jan 30, 2015 | 11:42 PM
  #40
Whipped383's Avatar
I'm not looking to go crazy. I'm at 5000 feet elevation so power sucks up here. Everywhere I tow my fifth wheel is uphill to so I loose even more power when I get up to 8-9000 feet. Adding the Whipple and running 3-4 psi is going to put me at the same power level as sea level and that's all my goal is.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
