NEED SUGGESTIONS For MODS
Old Sep 1, 2006 | 10:02 PM
TIM Z's Avatar
11 sec. Truck Mod
Default NEED SUGGESTIONS For MODS
Well, i have my dealer searching for a crew cab 2500 4x4 Duramax. I need some advice on mods cuz FIRST Thing I am going to get a programmer, exhaust, CAI and Wheels/Tires. SO what do you suggest?? IVE heard Good about the PPE programmer, but what about the Edge/juice/Attitude. Where can i get a reasonably price 5'' Exhaust with cat delete pipe and no muffler? What do you guys like for cold air intakes? I want to do it once and do it right. Thanks for the replys-Tim
Old Sep 2, 2006 | 01:23 PM
RubenZ's Avatar
Forget all of those first and get yourself a Boost guage and EGT Guage. That is your most important first mod. Then I'd get a programmer and Exhaust. If your dealer is finding a LBZ duramax the stock intake is just as good as any CAI out there so don't even worry about that.
Old Sep 2, 2006 | 01:48 PM
TIM Z's Avatar
11 sec. Truck Mod
They are looking for a left over 06 but im might just buy an 07 if i cant find one, Im getting impatient!! I know how important the gauges are coming from a turbo gas engine. What is the scale for EGT's ? what is stock boost set at and what is the safe limit for a stock LBZ?
Old Sep 2, 2006 | 02:47 PM
RubenZ's Avatar
That was the case for me. I wanted an 06' but they could never located the one I wanted. I didnt want bose or leather etc which is all that was left so I just bought a 07 Classic.
For answers to your other questions if you want the best Duramax info on the web join this forum, its for GM diesels http://www.dieselplace.com/forum/index.php
Old Sep 2, 2006 | 02:57 PM
nightrunner's Avatar
Mr. Obvious
i think the stock turbo puts out about 20-23 psi on stock program
Old Sep 2, 2006 | 03:03 PM
TIM Z's Avatar
11 sec. Truck Mod
Ok, so boost is adjusted up or down via Tuning?
Old Sep 2, 2006 | 03:17 PM
Mr. Obvious
i think it varies some but most turbo applications use the wastegate to control boost ( which you more than likely already know from the sts) but i think the duramax turbo has an internal wastegate
Old Sep 2, 2006 | 04:15 PM
TIM Z's Avatar
11 sec. Truck Mod
yeah, i wandered if the D-max had a computer controlled wastegate.
Old Sep 2, 2006 | 04:49 PM
Mr. Obvious
i believe it is but it is inside the turbo housing and the turbine vanes have varying angles controlled by the computer
Old Sep 3, 2006 | 01:38 AM
Trotorx2's Avatar
Tim the best thing for you to do is like RubenZ and I have said... join and READ. It is the best thing you can do. You will learn more and save $$$$
