My LB7 Dirtymax
Old Mar 22, 2013 | 12:03 AM
  #101
Spoolin's Avatar
GFYS and STFU
Cool, makes sense. Might be something to look into for my rig.
Old Mar 22, 2013 | 12:24 AM
  #102
Mangled03gmc's Avatar
Baltimore Whore
You need your bed off your 1500 on there, get a smooth side cap. (.Y.)
Old Sep 28, 2013 | 10:11 PM
  #103
AKlowriderZ71's Avatar
11 Second Hall Moniter
Well, I haven't updated this thread in a LOOONG time!
Tow mirrors are on, with the LED's wired to the park lamps & turn signals. Airbags, compressor, and gauge are installed, and some new 33x12.50R18/E Toyo MT's are on. I'm digging it!
Old Sep 29, 2013 | 10:43 AM
  #104
1FastBrick's Avatar
Custm2500's Rude Friend
Does Rogers Auto care still have the same number?
Old Sep 29, 2013 | 05:36 PM
  #105
hondarider552's Avatar
Always loved the 01-02 front ends more than 03-04 like mine! Looks good!!
Old Sep 29, 2013 | 08:22 PM
  #106
Only on my truck!!
Still looking for a location for the business here in Wyoming.
Old Oct 1, 2013 | 07:57 PM
  #107
black00chev's Avatar
Slowest turbo build ever!
Im looking into possibly picking up an '02 2500hd LB7 with about 130k miles on it. Anything I should look for?
Old Oct 1, 2013 | 09:19 PM
  #108
If you have access to a good scan tool, moniter actual fuel rail pressure against desired fuel rail pressure while test driving. They should follow each other closely. Then go WOT to 70 mph and watch for the same thing. If it can't hold rail pressure, it may need a CP3 or injectors.
Other things that I'd look at are the water pump, trans cooler lines, any drivetrain leaks, all u-joints, and check the front end too. Also look for serious rust or pitting on the rotors machined faces, and see if the transmission fluid is clean or smells burned. All the typical stuff that you'd check on a half ton gasser.
Repairs on diesels cost quite a bit more than gassers. Being able & willing to do the labor yourself will save you a ton, but the parts are more expensive by a healthy margin. If it's had a tuner of some type on it previously, check the transmission as thoroughly as you can. It's pretty easy to hurt a stock Allison with only a tune.
Old Oct 1, 2013 | 09:59 PM
  #109
ltr450ryder's Avatar
Duramax ftw lol had to throw it in there
thunder550
Oct 8, 2015 04:53 PM
AKlowriderZ71
Nov 28, 2014 11:35 AM
ssheathss
Jul 14, 2012 01:05 AM
TwnTrboCE
Mar 23, 2007 12:47 PM
EvilChevy
Jul 29, 2006 11:39 AM
