duramax fuel issue
Old 05-14-2013, 08:26 AM
  #31
hondarider552's Avatar
from the water in fuel sensor? They are super easy to cross thread.
Old 05-14-2013, 09:03 AM
  #32
sprayedenali's Avatar
idk what it is, but its the little plug thing that screws in to the larger hex thing at the bottom of the filter, once it started leaking i took it out and put it back in twice and its still doing the same thing...?
Old 05-14-2013, 06:00 PM
  #33
99LsSilverado's Avatar
What most likely happened is that the drain plug cracked when putting the filter in, I have done it a couple times myself, I would go to napa and get a new water in fuel sensor and put it in
Old 05-14-2013, 06:13 PM
  #34
I messed with it some this afternoon and it looked like it was just leaking past the seal on the plug and just coming out the hole in the middle. So I just plugged that hole and will see if that works when I get back home in a few hours
Old 05-15-2013, 07:39 AM
  #35
It seems like plugging that hole has at least helped the problem... It fired up after just a few seconds this morning, so at least it seems like its holding its prime now
Old 05-15-2013, 09:28 PM
  #36
I think new sensors are like 35-40$ Those junk plastic threads strip super easy
Old 05-15-2013, 10:12 PM
  #37
ya, since this has seemed to fix it ill grab a new sensor....
that or get a lift pump and get rid of this whole contraption. (i can do that, cant i?)
Old 05-16-2013, 09:24 AM
  #38
Yes you can. I have an Airdog II 165GPH and I totally removed the OEM fuel filter setup.
Old 05-16-2013, 10:28 AM
  #39
When you do that do you just put the two lines that go in and out of the factory filter together?
Old 05-18-2013, 01:55 AM
  #40
Yep. I used a new piece of fuel line to make it shorter.
Quick Reply: duramax fuel issue
