Driveshaft bearing ccsb 2500hd
Old Oct 10, 2015 | 06:58 PM
zeake's Avatar
Default Driveshaft bearing ccsb 2500hd
My muffler heat shield was rattling so I crawled under the truck to shove a rock into it. The last rock had abandoned ship after a trip to the dump. Anyway while I was under it I grabbed the drive shaft to use as a push point in order to slide around under the truck. Imagine my surprise as it moved.
It has not made much noise so I have not been concerned since I found the problem last week. Well tonight I put the gopro on it and drove around. I'm glad I did, that has got to be fixed. The video is kind of long, but you can see it moving forward. The stupid thing has messed up the rear seal on the transfer case.
This will be a fun fix.
Attached Thumbnails Driveshaft bearing ccsb 2500hd-img_20151010_192548932.jpg   Driveshaft bearing ccsb 2500hd-img_20151010_192554864.jpg   Driveshaft bearing ccsb 2500hd-img_20151010_192538342.jpg
Old Oct 12, 2015 | 10:23 AM
8.1 HD's Avatar
Back in late '01, early '02 GM did have bearing issues on ccsb trucks and offered to swap to a one piece driveshaft eliminating that center carrier bearing. I believe that '03 and up all have a one piece in the ccsb trucks.
Old Oct 12, 2015 | 10:55 AM
TXsilverado's Avatar
would GM still offer that on a 2002 2500HD? my bearing has been shot for about 20k miles now lol. all kinds of squeaks and grinding noises. I turn up the radio
Old Oct 12, 2015 | 02:30 PM
zeake's Avatar
Interesting. Mine is an 04. I was quoted $250.00 to replace it. I am thinking about doing it myself although I have no press.
Old Oct 12, 2015 | 02:42 PM
250 is high. I was quoted 120 including parts and a balance.
Old Oct 16, 2015 | 09:08 AM
zeake's Avatar
Well I did it myself with the exception of getting it off and putting the new one on the shaft. The one that was on it was made in China. The new one, only one they had, is made in Israel. I tried getting the bearing off with a long 2 jaw puller and it would not budge. The mechanic that got it off for me used an air hammer.
Old Oct 16, 2015 | 10:37 AM
how hard was the job? I have an air hammer...
Old Oct 16, 2015 | 11:13 AM
zeake's Avatar
It was not bad at all. The key is not to destroy the shaft as you hammer it. If you have moderate skills you can do it. A cup that the rubber boot goes into has to come off intact. The new bearing had one, but it did not fit at all. Luckily the mechanic got it off in one piece.
03sierraslt
11
Oct 27, 2015 03:38 PM
Vortec350ss
Oct 10, 2015 09:11 PM
Alco
Oct 4, 2015 06:58 AM
Jake99
Sep 16, 2015 10:14 AM
