D-Max Turbo Size?
Old Jul 28, 2005 | 11:05 PM
vanillagorilla's Avatar
Default D-Max Turbo Size?
What is the size of the D-Max's factory turbo? Isn't it internally waste gate'd too? Any info you guys know, like A/R ratio, inducer or exducer bore size would be helpful too. Don't the newer turbos have variable turbine area as well?
I'm just curious as to how the factory sizes the turbos for these beasts.
Old Jul 29, 2005 | 02:08 PM
craSSh's Avatar
The LB7's have the fixed vane turbo and have a wastegate. The LLY's use a VVT (variable vane turbo) in which the vanes position themselves according to how much boost is needed, and no wastegate is used. I don't know the size of either.
Old Jul 29, 2005 | 06:00 PM
Yeah, the one on the LLY is the one I'm thinking of. I don't understand how they don't use a WG on it though. That must be one finely tuned turbo!
Old Jul 31, 2005 | 12:50 AM
XLR8NSS's Avatar
Adkoonerstrator
The exhaust turbine uses adjustable blades/"vanes" to control the boost instead of a normal wastegate.
The turbine blades are not fixed like on a standard turbo.
Old Jul 31, 2005 | 04:50 AM
I understand that, but just like Aerocharger's old VATN turbos, they should utilize a wastegate.
Old Jul 31, 2005 | 08:03 AM
BMDMAX's Avatar
When the computer reaches max boost it will change the vane angle to limit the amount of available boost just like a wastegate. It is very responsive, in fact the LLY turbo is much harder to bark than the wastegated one on my LB7. When the blades are commanded fully flat you loose all boost in a hurry and it seems to bleed off much quicker than a wastegate setup.
Old Jul 31, 2005 | 12:15 PM
XLR8NSS's Avatar
Adkoonerstrator
The technology must be to the point where a wastegate is not necessary now.
BMDMAX - Thanks for the explanation.
Old Jul 31, 2005 | 03:16 PM
Wow! The computer controls the angle of the vanes!!! Damn that's sweet.
Thanks for the info, but what does it use to control the angle of the vanes? What does it use to KNOW the angle of the blades?
Old Jul 31, 2005 | 06:45 PM
BMDMAX's Avatar
There is a vane position sensor on top of the turbo that reads where the vane angle. The ECM then uses the APP, ECT, GEAR, LOAD, MAF, RPM and BARO to control boost. It uses the vane position sensor as feedback on what position the vanes are in at any given moment. It uses the boost sensor just to make sure the boost is at a pre calculated # based on load, rpm, ect. The vane position sensor is 1 volt when open and 3.5 volts when closed. One thing that the tuners are working on is if the ECM thinks the vanes are open a little more than they really are it should make more boost. Just don't fool it to much or the pressure sensor is going to tell the ecm that there is to much boost for this rpm/load and cause the sytem to throw a code or punt.
Gotta love technology.
Old Jul 31, 2005 | 07:14 PM
Wow! That's awesome! That's about as good as it gets for turbocharging.
TAPyvehc93
Jul 23, 2017 10:54 PM
Stainless Works
13
Nov 5, 2015 03:31 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
