Anyone try towing heavy stuff with a 408 LS?
Old Oct 24, 2018 | 01:59 AM
EmeraldFlame772's Avatar
Default Anyone try towing heavy stuff with a 408 LS?
I know its kind of a general question but I just wanted to ask hows it tow compared to a 6.0 on your 408 stroker build?
Old Nov 4, 2018 | 12:06 PM
LCDR's Avatar
idk but i have heard of reliabilty issues if a LS stroker isnt done right. The piston skirt comes out of the bore too far on the downward stroke and rocks. This causes acclerated wear and oiling issues(so ive heard) If i were to build one i would start with a tall deck block. I would ASSume that a 408 stroker would be good with towing since it has bigger pistons,longer rods,longer stroke the tourqe would be awesome. Then again im not a proffesional and talking purely from speculation.
Old Nov 4, 2018 | 02:20 PM
03sierraslt's Avatar
All of the above is true. Doesn’t have to be a tall deck though. You just need a block with longer skirts. But if your going that far then ditch the 408 idea and go bigger. (427)
Old Nov 4, 2018 | 02:50 PM
arthursc2's Avatar
Gen 4 iron skirts are considered the longest
Old Nov 7, 2018 | 02:25 PM
LCDR's Avatar
ya dont say? I was not aware of this. My block is from a 07 classic but it came with gen4 goodies. While its technically a lq4 it had gen4 rods,pistons(ly6) also has the spot for timing chain damper already threaded..im gonna go measure my sleeves..
Old Nov 7, 2018 | 03:57 PM
arthursc2's Avatar
Its not much man, like .03" longer than aluminum and maybe .05" longer than gen3, but I am just spitting out what Ive read online. I never measured my LY6 based 408 build.
Old Nov 7, 2018 | 10:24 PM
1994Vmax's Avatar
The Gen 3 blocks since mid year 2004 are all like that with hit or miss on the timing chain damper when they went to all equal length head bolts. It's still a Gen 3 block with the knock sensors in the lifter valley. I have seen the valve relief equipped piston in the last run LQ4 blocks though as GM was obviously setting up for the LY6.
I read this more and more but the full floating rod is not something that is unique to Gen iv either. Every mid 04 and newer Gen 3 had them and LQ9's came with them from the 2002 model year onward when the LQ9 debuted.
Old Nov 8, 2018 | 09:04 AM
2002_Z28_Six_Speed's Avatar
I have a 408 and I tow small trailers (7K lb). It was a pretty big difference especially in the mountains of VA and TN. I do downshift from 5 to 4. But never any lower than 4. I used to go down 2 gears on the stock motor and tranny -- sometimes. You could live without it in my circumstance though. 7K isn't much and not trying to go fast.
Old Nov 26, 2018 | 01:31 PM
I just did another pull from OK to VA with about 5000 lb of trailer and at least 600 lb of cargo in the suv. I pulled almost every hill in 5th unless a semi in front of me caused me to slow down too much and drop out of where my power was. Pretty good run. Shifted a lot less than the stock motor. Since I am only 1500 I am more worried about throwing my u joints or rear out than you HD guys.
Old Jan 20, 2019 | 11:43 PM
LSrBEST's Avatar
I had the longer stroke so was at 416 cubes. thing had gobs more torque. seams like I was always 1000 RPMs lower with the stroker getting my power.. Had to use that extra RPM to make the power on the short stroke vs not spinning the 4.125 stroke as fast to get same or more power as stock stroke. From what I've read Wiseco pistons have the best design in regards to the skirt being out of the hole, pin hight, and the other dynamics that come along with the piston coming that far out of the hole. You won't get 200k + Miles out of an engine with a stroke like that but you get cubes.. My 416 was with a .005 over hone.. Which means my block has lots of life left yet still yielded 416 cubes�� Big freaking deal if I run through a set of pistons 2 times as fast. in my case probably 4 times as fast as I built it to drive it.. Once you build an engine reliability along with gas economy IMO, are thrown out the window anyways. You want durability and power in a truck ditch the gasser and quite funkin around.. Get a Duramax. Had my 416 with 243's ported, tbss intake & 90mm tb, 224/228 @ .600 cam with a 2800 stall. Forged rotating assembly, machine work, gaskets, spent some money on the heads and the other obvious parts. Where I'm going with this is, had I have known what I know now, I would have went strait for a Duramax. My LBZ (dinosaur btw I know) with tunner is putting out around 660 tq & I want to say right around 400 HP. that's stock components with a tunner that switches on the fly.. I LOVE how it pulls. With some tranny work, a lift pump and some minor mods to stock turbo 600 HP and much more TQ is absolutely obtainable and safe. Could have done LB7 swap for the money I spent on the 416 if you stroke it you can't cheap out and you will spend money on machine work, rotating assembly, gaskets, bearings, I'm sure you'll do a cam because why would you open up a gasser and not touch the cam, then you almost indefinitely need a stall for any respectable cam and the rabbit hole continues. Lol keep your eyes out for a wreaked Duramax van or truck and ditch the gas. You'll have the engine out anyways.. I love my LS engines! Don't get me wrong! But if your your looking for towing and reliability there's no question about it. I picked up a front end damage 2500HD for $4600 I know there's ones cheaper too. And they come with the 11.5 AAM rear axle. Anyways it was less than I spent in the end on my stroker build and I know there's wreaked vans and trucks for less than I paid. if I could only turn back time
