8.1 engine options??
Old Apr 24, 2013 | 07:09 AM
scottybeammeup's Avatar
Default 8.1 engine options??
I have an 03 HD with the non supported 8.1 red headed step child motor. The only good crank for this thing comes in a MerCruiser 496 Mag, nut's. I would like to build a motor with 500+ Hp's (basically just a number) and put out 600+ foot pounds of torque (the good number). Not to sure the stock crank would hold up to that. Has any one ever put a 454 block in for a replacement? It would be nice to retain all of the drive by wire stuff, cruise control is a must. From what I've read the only thing this motor shares with any other BBC is the exhaust manifold, and nothing else. Thanks
Old Apr 24, 2013 | 08:54 AM
whippled 8.1l build's Avatar
raylar is pritty much the only after market company for the 496 engines..
Raylar Big Power 750 High Output 600ci Engine
Old Apr 24, 2013 | 09:58 AM
I see that Dart has heads and a block, what good are they without a steel crank.
Old Apr 24, 2013 | 10:07 AM
Kemble's Avatar
Did you even check out the link to raylars site? They have just about anything you would need.
Old Apr 24, 2013 | 11:53 AM
Yes, and like you say, Just About. If a 454 block would bolt up to the Allison trany and the drive by wire throttle bolt up to an intake, then I would have a MILLION options for vendors, not one that would/could just stick it to you. Stroking a 454 to any size is cheaper than dicking with a gen 7. I'm sure I'm not the only one looking into that option or even thinking about it.
Old Apr 24, 2013 | 08:18 PM
TieRod's Avatar
Throw a turbo on it and call it done.
Old Apr 25, 2013 | 08:40 PM
Trick doesn't have a manifold for their unit. I could buy the parts and do it STS style. I've been toying with the idea, it would sound nice.
Old Apr 25, 2013 | 10:29 PM
TieRod's Avatar
My 03' went 13.3? @ 101mph on 12#.
Old Apr 26, 2013 | 05:04 PM
Must have been before it caught on fire, the avatar pic??
Old Apr 26, 2013 | 07:47 PM
TieRod's Avatar
That was my 01'. It had Raylar head, crank, intake, and cam with 200hp of nitrous.
This was my 03'. Unfortunately I had to sell it.
8.1l STS Turbo at the track - YouTube
