270 cam in my 8.1, lil' hole in throttle blade?
Old Jul 26, 2014 | 03:06 PM
jmccart's Avatar
Default 270 cam in my 8.1, lil' hole in throttle blade?
I read this on here somewhere a bit ago, about this helping the idle. I can't find it now. Anyone know about putting a lil' hole in the throttle plate to help idle?
Thanx.
Old Jul 26, 2014 | 03:44 PM
jmccart's Avatar
Never mind, found it
https://www.performancetrucks.net/fo...ho-has-529123/
Does the purpose of the hole I the throttle body only aid the modified intake? Or will it be good foe a 270 cam & stock intake?
Old Jul 27, 2014 | 11:10 AM
MustangPunk's Avatar
The purpose of the hole is to allow for more running airflow into the engine at idle so the Idle Air Control stepper counts can be lowered back to near stock levels to easier control idle. You need to drill if you cant get the IAC count down to where it needs to be, if you can get it running without the hole and have decent IAC count then don’t drill it. This is non electronic throttle body right?
Oobray
Jun 13, 2022 03:38 AM
Ammadien
Jul 22, 2015 08:50 PM
jrplz
Jul 9, 2015 12:07 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
