07 chevy silverado nnbs kill switch
Has anyone ever installed a kill switch on their truck? What would be the best way of doing it? ThruFuel pump wiring ,ignition ? Wanting to install one on my truck any help would be appreciated thanks
Registered User
The best technique I have seen is to unplug the ground from the ECU. If you disconnect ground it is very uncommon and will make it so that even if you have fuel the truck won't run.
When you do a fuel pump cut off it is common and people know where to look, same with the ignition.
supershift67
09-07-2016 12:01 AM
