what thermostat for my 05 4.8 5 speed? any hp gain, and when do stock fans come on?
Old 09-14-2010, 10:38 AM
Justinrst's Avatar
Default what thermostat for my 05 4.8 5 speed? any hp gain, and when do stock fans come on?
What temp does the 05 4.8 5 speed fans come on? any benefit to a lower thermostat.
Old 09-14-2010, 11:39 AM
There was a lot of discussion about this a while back, and it's my "new" opinion that unless you're boosted, the lower t-stat won't do a hell of a lot for you. You might be able to squeak a little more timing out of it, but I doubt that you'd notice a difference. I'm running a 160* stat and I've been happy with it, but whenever I get around to building my LQ9 I'll probably go up to a 180* stat. The factory stat is 195* I believe. Not sure about the factory fan settings, but I know that it's over 200* when they come on.
From what I remember reading, the LS engines seem to perform the best and most efficiently between 180-200*
Old 09-14-2010, 11:03 PM
brent5631's Avatar
Mine are set at like 203-207 or so.
Old 09-15-2010, 03:42 AM
supercharged680's Avatar
https://www.performancetrucks.net/fo...ght=thermostat ull find some good info here..
Old 09-15-2010, 09:10 AM
Justinrst's Avatar
thanks guys i know lowering the thermostat kills MPG so I'll wait till i do the blower and revisit this
Old 09-15-2010, 11:04 AM
06Sierra2's Avatar
how does lowering the thermostat kill gas mileage?
Old 09-15-2010, 11:10 AM
The PCM is in a colder enrichment mode at lower temps, so running the engine cooler without tuning the PCM to compensate may have a negative affect on fuel economy. If the PCM is tuned accordingly though, fuel economy will not be affected.
5.3Okasai
03-09-2022 01:07 PM
SLOPONY
20
10-18-2016 06:05 AM
thunder550
10-08-2015 04:53 PM
ou812sm
07-18-2015 01:12 PM
Quick Reply: what thermostat for my 05 4.8 5 speed? any hp gain, and when do stock fans come on?
