Which 2 stage Boost Controller to buy?
Old Aug 3, 2005 | 10:41 PM
TG02Z71's Avatar
Default Which 2 stage Boost Controller to buy?
Soon I will have my 5psi level system to its best capabilties. After that is done and track tested I will be going to up the boost to 8-10psi max. Bigger injectors on the list as well as an intercooler set-up, but which 2 stage boost controller are you guys using? STS has one but their site sucks for pics and technical information. Let me know what you are using and how happy you are with it and how hard was the install.
Thanks guys.
Old Aug 3, 2005 | 10:57 PM
parish8's Avatar
single digit dreamer
i have the blitz sbcid(plus power meter) or something like that. it was way to expensive but it is prety cool, i think it was around $700 total for both parts.
it has a bazilion features and is easy to use and hook up. best feature is speed based boost. it has up to 4 settings you can dial in at any speed you want. in my case something like 10psi up to 15mph, 12psi to 30mph, 14psi to 60mph and 16+psi from 60mph and up. there aren't too many controlers with speed based boost ability and that is why i got this one
Old Aug 3, 2005 | 11:03 PM
quicksilverado's Avatar
What did you tap into to get the mph reading? Do you have a web site link for the boost controller?
Old Aug 3, 2005 | 11:11 PM
parish8's Avatar
i taped the speed sensor under the truck. it was easy.
here is a link to 1/2 of the unit, there is a "power meter" part you will need to for the speed based boost control. together they were around $700. http://www.velocityfactor.net/script...?idproduct=664
Old Aug 3, 2005 | 11:35 PM
TG02Z71's Avatar
$700.00 YIKES!!! A little rich for my blood but a very nice peice!
Parish do you have this mounted where the air bag switch is?
Old Aug 3, 2005 | 11:43 PM
TG02Z71's Avatar
Maybe I should ask what should I stay away from instaed of what should I get.
My truck will not advance much past the point in my first post in the thread so what would be too cheesy of a unit and what would be overkill for me?
Thanks again guys.
Old Aug 4, 2005 | 11:07 AM
Mort's Avatar
Cool
I have the STS Boost Controller because they gave me a good deal on it.
It uses the spring in the wastegate for the base level and you set the upper level with a control valve from an air compressor. From there it goes to a switch valve like the one used for the PCV Control. The switch valve is activated by a switch with an indicator light in the cab installed in a location of your choice. I put mine just below the instrument cluster to the left side of the steering wheel. It is simple and works well enough for my needs. I think it will work up to about 15 PSI and works by applying pressure to the opposite side of the wastegate from the spring. So if you have a base psi of 5 and apply 3 psi with the controller you get an upper level of 8 psi. So the valve must be set to work from 0 to 10 psi. You adjust the upper boost level by crawling under the truck and turning the **** on the air control valve.
TurbosmartUSA makes a full range of boost controllers and I am sure you will find one to suit your purposes and price point. They will alow you to adjust your upper and lower boost levels AFAIK and have an electronic series as well $$$$$.
Old Aug 4, 2005 | 11:08 AM
JERRY2500's Avatar
14 Second Truck Club
Same here and works great. I have my regulator by the wheel well so i don't have to crawl under the truck. I'm getting to old for that stuff
Old Aug 4, 2005 | 04:44 PM
TG02Z71's Avatar
I think I saw pictures of someones set up a while ago, is this what you guys are talking about? I cant seem to find the adjustable valve pic but I did find the hose routing pic I saved.
Do you guys have any other pics of the STS set-up for boost control?
Old Aug 4, 2005 | 05:54 PM
Wilde Racing's Avatar
How do I change this text
Hey that is my truck lol. Here are a few more pics, and the reg mount pic.
I have the contol valve mounted under the tube crossmember.
