4L80E transmission fluid type??
Old 10-20-2011, 04:58 PM
Laid Back
Beatdown Z's Avatar
Dex III it is!
Old 10-20-2011, 09:18 PM
Hunt&Fisherator
silver-mod-o's Avatar
I've been running Merc V because it's free and I change the fluid extremely often, but back when I was having to buy it, I ran the cheap-o store brand Dex III. Never had a lube related issue with either.
Old 10-20-2011, 10:34 PM
charcold-bowtie's Avatar
Ive always used the cheapest dex3 I can get.
Old 10-20-2011, 11:08 PM
EVILGMC's Avatar
dex 6
Old 10-20-2011, 11:22 PM
mhotrodscooter's Avatar
I put dex/mec in my hd & pulled the stick to check the fluid level & it dex v only.. Does it matter?
Old 01-20-2012, 05:34 PM
chris092183's Avatar
I was using this fluid too, i used it only to flush the crap out of my old trans when I installed the hd2. I never got to put in my dex 6
To the builders:
Not questioning why you say to use dex 3 but what are the advantages over dex 6? is dex 6 too slippery because it is synthetic like synthetic is too slippery in truetrac rearends? I have already purchased dex 6 for my build. should I return it for dex 3 or is it not that big of a deal?
thanks
Old 01-20-2012, 08:56 PM
livefast1's Avatar
I had heard from pete at hughs performance that in his experience, synthetic fluid is grest for the clutched but is really hard on moving parts. Usually resulting in brinneling, then damage.
Old 01-30-2012, 10:11 PM
oldred95's Avatar
An old GM tech told me his opinion on Dex 6 is that it doesn't have the viscosity to lubricate properly in older transmissions. He said their is a reason why they say to use Dex 3 in the 07 classic and older transfer cases for one example.
FWIW I put a bottle of Lucas additive in mine along with Dex 6 while I had it on the bench installing the shift kit. It never gave any problems but it was only seeing 400 hp at most.
Oobray
06-13-2022 03:38 AM
XL7
05-05-2022 01:48 PM
bighouse
09-27-2015 12:37 AM
Go5.3tt06
09-12-2015 09:29 AM
zaathur151
07-06-2015 10:57 PM
Quick Reply: 4L80E transmission fluid type??
