4L80E Transgo Shift Kit Install Help
Old 08-08-2015, 02:01 PM
lycominghunter's Avatar
Default 4L80E Transgo Shift Kit Install Help
I am finishing up the shift kit on my 4L80e. Im in the process of finishing up the transgo HD-2 shift kit on my 4l80e. I replaced the spring for the reverse/low servo piston per the transgo instructions. When I reinstall the piston into the trans, I don't believe that the servo piston is pushing into the trans as far as it should be. The piston is seated up in the piston housing near the front of the trans, however the piston face is slightly below the piston housing edge towards the rear of the pan. If I try to install the accumulator cover, there is approximately a 1/8 gap between the cover and piston housing faces due to cover to piston contact towards the rear of the pan. I can install the accumulator cover flush with all the bolts with ease, however I believe I remember the piston being farther up in the piston housing when I disassembled. Any help would be greatly appreciated. Thanks!
Old 08-08-2015, 04:12 PM
treylittlefield's Avatar
Got a pic of it?
Old 08-08-2015, 05:20 PM
Yes Sir. I can try to get better pics if need be...
Attached Thumbnails 4L80E Transgo Shift Kit Install Help-rl-piston-1.jpg   4L80E Transgo Shift Kit Install Help-rl-piston-2.jpg
Old 08-13-2015, 07:03 PM
Bump! Still trying to figure this out. Thanks for the help
Old 08-15-2015, 12:26 PM
James B.'s Avatar
The spring pressure is consistent with my experiences with these. Fairly strong spring too, takes force to hold the cover down while you get the bolts in. Doesn't seem like a problem to me.
thunder550
10-08-2015 04:53 PM
1slwgto
08-16-2015 06:40 PM
Ammadien
07-22-2015 08:50 PM
lxcoupe
07-21-2015 02:12 AM
zaathur151
07-06-2015 10:57 PM
Quick Reply: 4L80E Transgo Shift Kit Install Help
